Question about Vacuums
Power down while vacuuming - Vacuums
  • leo_bateman Apr 30, 2008
    with Miele S758 vacuum cleaner. Occurs continually.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559408
Generic problem for all Vacuums
Posted by leo_bateman on Apr 30, 2008
Power down while vacuuming Comment by leo_bateman, posted on Apr 30, 2008
With Miele S758 vacuum cleaner. Occurs continually.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would advise checking your owner’s manual, it sounds like it could be a motor going bad and It might still be under a factory warranty depending on when you purchased the item, check the owner’s manual for the trouble shooting part to see what is going on and I will also give you some phone #’s listed below to assist you with your problem. Part of which might be the belt if it is a flat belt – it does require changing every 4 to 6 months and if it is a geared belt then you should replace every year or so for the best cleaning. Or you may have a bad connection or computer board that is going bad. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 30, 2008
The power button will not stay depressed. Vacuum will work if I hold it down.
It is caused by loose power buttons Spring or broken lock. open the cover & replace power switch.if u not able to do contact mechanic
Mar 02, 2015 | Dyson DC41 Animal Vacuum
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
No power what do I do when I stopped and tried ti start again no power . Emptied it and cleaned filter but still not working
All vacuums generate heat and some have automatic cut off switches when the vacuum does overheat. When this happens the manufacturer does not want you to just turn it back on, they want you to know there was a problem and to let it cool down. They often do this with a restart button. Having to press a restart button is supposed to make you think a bit more about the problem and, perhaps, let the motor cool down before restarting the vacuum. The button is often small and red.
Sep 15, 2014 | VAX Appliances Vax X3 Bagless Upright...
Eureka powerline umc-18 vacuum quit working
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Dec 18, 2013 | Eureka 1810 Central System Vacuum
Bissell 5770 vacuum power won't stay on. The power will only stay on if you hold down the button the whole time.
I just had this happen to me. I took the top part of the vacuum off, unscrewed all of the screws from the top piece and opened it just enough to pop off the plastic red power button. Then I pressed the switch mechanism up and down a few times to reset it and put it back together. Turns out it didn't actually go bad.
Feb 28, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Power button won't stay on. If I hold it down, it sucks fine, but it won't stay pushed down.
Take it to a local vacuum repair shop and have them replace the power switch, once you do that your machine should be back to normal
Sep 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum cleaner power loss
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545672
Posted by fudpucker on Apr 25, 2008
Vacuum loses power while operating. Just shuts down and will not restart by toggling switch. After a brief (cool down?) period it will start.
Is there a breaker/reset? Does it have a feature that automatically shuts it down when the bag is full?
I can't locate my owner's manual, so am completely in the dark or dirt.
Depending on the Brand name and Model # there is what they call Thermal Switches on some of the vacuums that prevent the motor from over heating and possible burn out of the motor If the hose is clogged, the bag is full or the filter is dirty and the air does not flow threw the filter. Any one of the three situations could cause the vac to say “cut out” and stop the motor. So check with your local vac dealer.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
120 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
