Leadtech winfast px 7950 gt tdh
I have dell system dimension 5150 ram 1gb cpu 3.2 gh 2m cash mother bord 945 it came with the system there is a problem when i instill my vedio card winfast 7950 gt tdh pci exp. during boot the system tell me to push f12 bottom to dignose my system. when i push this bottom the display bacame black and i can,t see anything but when i remove my tv card and i push f12 the display apeare again with all catigories on my bultin tv card on my mother board so please help me to solve this problem
    Problem Solver:
  • 6 Answers
The 7950 will have a higher requirement for power than came stock with the machine, you probably need a better power supply to run this card. However Dell needs specific power supply units so you'll need to contact Dell about getting an upgrade!
An upgrade with a non Dell power supply unit is possible but it requires a little tweaking of the case.
Posted on May 01, 2008
Dimensions 9100 added RAM now won't boot remove batery and will boot or reboot not from power off
Possibly a bad power supply. If you remove all the memory and it still won't power up unless you remove and re-insert CMOS battery that is a symptom of a defective power supply
Nov 10, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I need a diagram for the mother board
http://support.dell.com/support/edocs/systems/dim5150/en/om/WD846A02.pdf
Try the above might help.
The board you put in should have a model no ont and rev no.
Cheers
pcfixit
May 06, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Upgrade cpu
It is a bit of a crapshoot trying to upgrade a processor from a major manufacturer. Their motherboards are designed specifically for the manufacturer and documentation on exactly what will work NOW compared to when the unit was new is rather hard to come by. They don't support people upgrading very well compared to the aftermarket manufacturers.
You should go to dell.com and put in your service tag to check your exact configuration yourself before spending any money.
According to Dell, the Dimension 5150 has a motherboard that uses the Intel 945G Express chipset. You can see INTEL'S documentation on that chipset's capabilities here. According to that documentation you can use a socket LGA775 with up to a 1066 MHz system bus speed.
Looking at Newegg, the fastest LGA775 processor with 1066 MHz are a 2.93GHz Duo core or a 2.4 GHz quad core. Again, no guarantees either will work with your system, and you definately want to make sure your power supply and case cooling are up to the task.
Mar 21, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
My computer shuts down when i play or when i exit 3d games
Hi, has the problem recently started after the installation of sp3 because it has been known to cause problems like your having. If the computer is a new build it could be one of two problem, the asrock motherboard which i personally wont use anymore because of constant failure, or your power supply is not powerful enough. i would recommend nothing less than 500w power supply for gaming pc`s.
Hope this helps,
Dec 15, 2008 | Leadtek WINFAST PX6600 GT TDH EX SLI 128MB...
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
