Not indicating hard drive
Hello sir,
i ve been trying to install operating system in my computer,but the computer does not see the hard drive,it keeps on saying hard drive not seen,what can i do?
  • 154 Answers
Usually a hard drive needs to be recognized by the bios (small programe chip on the motherboard) check to see if the hard drive is listed there (if not try a seek by settings to auto ) if the harddrive is recognized but not partitionned or formatted it depends on the operations system you want to install
it is also so that for installing the OS on to the harddrive you temporairilly have to change to boot settings and usually the OS dics has to be bootable .
Posted on Apr 30, 2008
Hello my laptop keeps saying no operating system found
This is a problem with recognizing your hard drive or the Operating System installed on the hard drive. Put your Windows 7 or Vista CD into your drive and restart, booting to the CD drive. Try to repair your startup problems. If this does not work, you may have a hard drive failure.
Feb 10, 2015 | Toshiba Satellite A300-0CF035 Notebook
I'm installing a biostar a78ldm2s and everything turns on but I keep getting a read disk error on the hard drives that I try to use. I've tried 5 different hard drives and get the same result.
Hello here you can download a manual:
By entering the right mainboard number.
Try to set the bios to factory settings.Load default settings.
And set the boot order: first boot device:dvd, second, the harddrive.
If you are using a IDE drive make sure its set as master.
A sata drive does not have that function.
Make sure the windows disk is clean and without scratces.
Here is a youtube video that shows you how:
Good luck
Nov 04, 2012 | Biostar A780L Motherboard w/ AMD Athlon X2...
How to solve this problem?
Does it get to the Operating System screen? ie, anything that indicates a Windows system or similar OS? If it doesn't make it to the OS screen I would say that there may be a problem with the hard drive, in which case you can try re-installing a clean version of your operating system, which would require you to lose your data. If your adequate with computers I would say take the hard drive out and retrieve any data you want to keep by using it as a slave drive on another computer. Otherwise you may want to take it to a computer expert to get the data retrieved for you. If you can live without it than get an operating system disc and do a clean install of the operating system, which should fix your problem.
Aug 17, 2012 | Gateway LT4004u 1.6GHz 250GB 10.1-inch...
It keeps opening up to startup repair
Have you tried a full recovery of the operational system to factory setting? if yes! it indicates hard drive issues, or windows files have been corrupted. If you have cd installation disc it will prove if there are hardware problems, or it will load windows.
Apr 14, 2012 | ASUS X52JCXR1 156 Notebook PC
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
Hello, i have sony vaio VPCEB46FG laptop & i have windows 7 64bit operating system & i want to install windows XP 32 bit but im getting following error "a problem has been detected and...
It is required to install the hard disk SATA drivers in the computer first. Download and extract the SATA drivers in a floppy drive, hard drive or CD on a different computer. Then, retsrt the computer by having the Windows XP disc inserted and beging the setup. During the setup process press the F6 key and enter>enter and then install the SATA drivers. Then, continue with the further setup process.
Select Windows XP Operating System and install the SATA drivers. Once, the SATA drivers are successfully installed you can continue with the further setup process with out errors.
You can also view a complete set of instructions on downgrading to the Windows XP Operating System and installing the SATA drivers.
May 31, 2011 | Sony VAIO VGN-S460 Notebook
Sir, Good day! How to reformat my hardrive toshiba dynabook without dvd drive
You'll need to remove your hard drive, hook it up to another computer via a USB to Hard Drive adapter and use the operating system of the other computer to reformat the hard drive. This will only reformat the hard drive, not install a new OS. To install a new OS you'll need a DVD-ROM and OS installation disc, or a flash drive with an OS installer on it to install from the flash drive.
Mar 25, 2010 | Computers & Internet
Plugged it in and the computer states there was a problem and will not recognize it have XP operating system Firelite 250 gb 5400 rpm
If the hard drive that you're installing has an operating system on it already, like Windows XP, you can't just move the hard drive from machine to machine if the computers are different. When you install Windows (or most other operating systems), the operating system customizes itself to the hardware in the computer. If you pull that hard drive out and install it on a completely different computer, Windows will most likely fail to boot and give errors and blue screens. This is normal. You will need to reinstall or repair the operating system if you want to keep the new hard drive in the machine.
Mar 07, 2010 | Computers & Internet
My Computer does not recognise the Maxtor 3200 personal storage
hdd problem,, 50% can fix you hdd.. if you have inportant data just make recover.. you can't use that for install program and operating system just only for external, save data but dangeros also maybe someday it wil not work totaly..
try to change the board if could
Jun 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Unable to install operation system in my sony vaio pcg-v505bx
what you may have to do is write the OS on an other computer by linking the hard drive of the laptop to a computer with a CD ROM drive. after you write the OS on the hard drive you place it back on the laptop with no drives.
Jul 04, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
