Question about Motorola Mobility RAZR V3
Bluetooth handfree not working
I can't get any kind of connection
headset: JABRA BT150
bluetooth energie : on
handsfree -> cant detect the headset
Txs for the advice,
i got the problem fixed now
Posted on Apr 30, 2008
  • 537 Answers
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
Cannot detect my jabra bt150 w/ my blutooth!
its a kind of virus prob plz scan ur cell
May 08, 2010 | Jabra BT150 Wireless Headset
Making jabra bluetooth headset work with motorola v9 phone
have you made the headset viewable by while its off holding down the power button untill a constant red light comes on. then searching for the headset
Mar 21, 2009 | Jabra BT150 Wireless Headset
Is my phone compatible w/ the jabra bt150??
bluetooth headsets are compatible with any phone that has bluetooth to connect just while its off, holding down the power button untill a constant red light comes on. then searching for the headset
Mar 18, 2009 | Jabra BT150 Wireless Headset
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Connect jabra to blackberry
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT150 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 19, 2008 | Jabra BT150 Wireless Headset
Trying to pair my N95 to my parott
Which handsfree set do you have?
You can find userguides on the parrott website for several models.
These describe very well how to connect.
Normally you should just activate bluetooth on your n95, search for bluetooth devices and connect to the handsfree set. Password is 1234.
Please post some feedback.
Apr 24, 2008 | Jabra BT150 Wireless Headset
Ear piece
Hi Snuggle ,
It depends on kind of cellphone you have. Normally there should be an option of Handsfree in the phone settings. choose bluetooth device it should detect the handsfree from there . connect to your earpiece from the list of devices.
for Example : I have Sony Ericsson W700i
I have that option under Main menu -- > Settings --> Calls --> Handsfree
Hope this is Helpful
Mar 19, 2008 | Jabra BT350 Bluetooth Headset Headset
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Jabra connection
Oct 02, 2007 | Jabra BT150 Wireless Headset
Motorola Mobility RAZR V3 Logo
121 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
