The printer will not print. A dialogue box appears stating that the print spooler was unable to connect to your printer. Printer turned off cable unplugged (no,no) or being connected to a vpn which will block access to your network?? No network simply printer plugged into computer...???
  • homemasters Jan 05, 2009
    I have the same problem apparently there is a trojan or something like that still no hope
  • 62 Answers
You could try to uninstall the printer driver, and reinstall it, but first try a different printer cable
Posted on Apr 30, 2008
My problem is its printing the test sheets but not the documents i want it to
How is your printer connected ? Thru USB Cable or On network ( router ) ?
If it is cable connected ( USB ) try the steps below
Disconnect the Cable from printer and PC and Reconnect and try to print.
If this does not help, Try the steps below
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
(If you are using Windows Vista/Win 7, You need to click on START button and under search program and files - Enter the Services.msc and click the same program from Program list that appear )
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Regards,
Sean
Jan 29, 2013 | HP LaserJet 2100 Printer
When sending a doc to print it reboots the computer
There could be lot of reasons for this to happen.
First, It could be because of faulty/corrupted Cable if you are connecting your printer to PC with USB Cable.
Secondly, it could be because of Driver mismatch, you need to uninstall and reinstall the printer software/drivers
Or it could be problem with Printer spooler.
Try the steps below
Regards,
Sean
Jan 22, 2013 | Lexmark Office Equipment & Supplies
Unable to add printer there is spooler problem
1. Click Start -> Run 2. Type services.msc 3. Services window appears, Scroll down and look for Print Spooler roadfox_3.jpg
4. Click on Print Spooler, Click on the Drop down box set it to Automatic
Jun 04, 2011 | HP DeskJet F380 All-In-One Printer
"Window cannot connect to the
You must restart the Print Spooler Service. To do this you must be logged in as an administrator:
1. Press the Win Key (between left "ctrl" and "alt) + "R". That will open the Run Dialogue Box.
2. Type "services.msc"
3. Scroll down to Print Spooler
4. Right click ----> Properties
5. Verify startup type is "Automatic"
6. Click "Start" ---> "Apply ----> "OK"
Oct 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
Print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Nov 07, 2009 | HP Color LaserJet 2600n Printer
The printer won't print PDF and says printer stopped despite reboot on/off
Try restarting the print spooler.
Open up a command prompt by clicking on the start button then selecting run. In the run dialogue box type cmd and hit enter. Once in the command prompt type net stop spooler. It will then display some text saying that it has stopped. Once it has type net start spooler and try printing again.
Btw, what PDF printer were you using?
Regards, Chris
Jun 27, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
May 22, 2009 | HP LaserJet 2200dn Printer
Print spooler
Usually, from the program you create your doc in, the OS will send it to spooler in the printer language. This is good as it then lets you get back to work, freeing up the processor. In some OS you can print direc t to printer ((setting usually in print dialogue box.
Apr 24, 2009 | HP Office Equipment & Supplies
Everytime i turn my computer on and try to use my printer won't go untill i go to printers&faxes and reset the default from one printer to the other printer-the icons in the printer/fax box are as...
Once remove the USB cable from the computer and perform spooler refresh by performing the below steps:
1. Click start >> run >> type >> services.msc >> locate print spooler and then right click on it and select stop and then again right click on it and select start.
Now open the printers and faxes folder and then try to delete the icon which is stating deleting.
Now right click on the other printer icon and click on properties >> adavanced tab >> print directly to printer >> click OK.
Now connect the USB cable to the computer and then try to print.
If you are still not able to print then remove the USB cable and delete even the other printer icon and insert the CD and click on add a device and follw the instructions and connect the USB cable at the middle and then try to print once it finishes.
We experience this type of issues if the printer driver is not installed properly.
Jul 04, 2008 | HP Office Equipment & Supplies
203 people viewed this question
jasbo
jasbo
