Question about ASUS P4SE Motherboard
Memory 1 gb with pc 3200,can i use in p4se? - ASUS P4SE Motherboard
    Novelist:
  • 119 Answers
Dear blatz
The ASUS P4SE - motherboard Supports DDR SDRAM RAM.
The Supported RAM Speed is: PC2100, PC1600, PC2700
This means that the speed is at a maximum 333Mhz. The PC3200 is rated at 400Mhz but its ok. It is backward compatible with PC2700 or 333Mhz.
It will simply work but not at its maximum speed.
Regards
EngineerGR
Please rate this solution as Fixya if you found it to be usefull, this keeps us going. :)
Posted on Apr 30, 2008
DDR-400/PC-3200
if the memory supports those frequencies, in most cases it would work, now depending if the board is proprietary, like dell or some hp's, then you may run into compatibility issues. you can find this information from the manufactures website.
Oct 16, 2013 | Computers & Internet
MY HP Presario SR1710NX won't recognize the 1 gig memory chips I have
Is the Memory PC-3200? Let me get this correct, you have installed 4 1 GB's of PC-3200 Memory in 4 DIMM slots. If you shut down, unplug, check/reseat memory mods, plug in ,reboot, Open BIOS, Check Memory installed, what does it say? I looked at the specs for KVR400AK2/1GR it's saying it's 2x512mb's? I'm confused? Is this it? http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=84387&site=cp Download this little Freeware program, it will help: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=84387&site=cp
Dec 30, 2012 | HP Presario SR1710NX (CPQSR1710NXEL426AA)...
WHAT MEMORY COMPATIBLE?
DDR PC2700 or PC 3200 RAM is compatible.
Up to 1 GB per slot.
Here is a link to Crucial for RAM that is compatible:
Computer memory upgrades for ASUS P4PE Motherboard from Crucial com
Sep 14, 2011 | ASUS P4PE-X Motherboard
I upgraded my gategay gt-5428 computer memory 1 gb to 2 gb but still runs with i gb, what i did wrong?
Hello Erik,
Are you absolutely certain that the new module is compatible with your system? Go into the BIOS and see if it is recognized there.
Crucial shows that your computer takes DDR2 memory with support for DDR2 PC2-5300, DDR2 PC2-6400 speeds.
Make sure it is not ECC memory. ECC is not compatible.
If you are sure of the compatibility, I would try to install the old one by itself first and make sure the system boots. Then I would remove the old one and install the new one by itself. Try booting. If it doesn't work, you may have gotten a bad module. (It happens.)
Just FYI, here is the crucial link for your computer:
http://www.crucial.com/store/listparts.aspx?model=GT5428
Thanks for using Fixya.
Feb 27, 2011 | Gateway GT5428 PC Desktop
Where can I get a user manual for a CISNET model C133-B81 computer ... can't find anything on the ZT Group website. I am looking for info on the maximum RAM capacity and type of RAM installed.
In an attempt at finding your user manual, I dicovered that this is the closest thing they have. So... What I would do is follow the directions in the link above for removing the memory. Then I would read the label to determine what kind of memory is in it. If it is DDR1 (PC-1600 - PC-3200) then the max will be 1 GB x no of slots your machine has, Thus if you have two slots your max will be 2 GB (1 GB x 2 slots = 2 GB). If it is DDR2 (PC2-3200 - PC2-8500) then you max will be 2GB x no of slots. If it is DDR3 (PC3-6400 - PC3-17000) then the max will be 4 GB x no of slots.
Best regards
Dec 28, 2010 | ZT Group Cisnet PC Desktop
# of RAM slots
There are two models for this type of desktop, the first having only two DIMM slots, but that takes PC2700 Ram, you have stated that yours takes PC3200 which would make it the second model in which case your model has (4) DIMM slots, each slot is capable of holding a 1 GB stick of ram for a total of 4 GB. Your RAM specification is DDR PC-3200
Jan 12, 2010 | Computers & Internet
Upgrading To Vista
I recommend buying the memory from crucial which is 100% guaranteed to work on your system, if you want to buy the memory at a local store, please print out or write the memory type down on a paper from the crucial memory scanner to know the right type of memory to buy.
Jan 16, 2009 | Computers & Internet
I want to install memory on a Compaq SR1503
The following list shows what your basic computer came with and approx what you
can go to. When ordering make sure you specify speed and type
Memory Installed 256 MB (1 x 256) Maximum allowed 4.0 GB* (4 X 1 GB) requires the replacement of the installed 256 MB DIMM
*Actual available memory may be less Speed supported PC2-3200 MB/sec Type 240 pin, DDR2 SDRAM
Oct 02, 2008 | Compaq Computers & Internet
ASUS P4SE Motherboard Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
