Question about Canon PIXMA MP460 All-In-One InkJet Printer
Naffed printer it is saying i have a paper jam i cleared it and pressed okay button but it wont clear and is still saying that there is a jam
  • 537 Answers
Are there any small fragments of paper still in the paper path? I would inspect closely. Also on this printer, look at the back part of the printer and see if there is a little door that you can open to check and see if paper remains there. There is either paper there, or the paper feed sensor is blocked or damaged.
Mike
Posted on Apr 30, 2008
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
It says open door, clear carriage jam and then press okay to continue
This means you have a paper jammed inside of the printer, you need to open some of the access door to find and remove it. then you can press okay to continue printing.
Mar 01, 2011 | Office Equipment & Supplies
When i try to copy, paper goes into the printer and gets stuck mid way followed by error message "paper jam, clear ...". If i press the okay button again, the paper is ejected out.
Make sure the access panel/bar at the back of the printer is fitted in properly.
If you have removed it to clear a jam, it may not be seated properly.
Try to see if perhaps some paper is stuck in the rollers, or maybe your rollers are sticky
Use correct weight of paper - it does not really like card stock that much.
Make sure Junior has not shoved a pencil into the printer tray, etc.
Let the panel know if you were able to clear the jam and how you did it.
Dec 12, 2010 | HP PSC 1610 All-In-One Printer, Scanner...
CLEAR PAPER JAM,
do a maintenance task on your printer.
do a roller cleaning, paper feed, etc.
or you can do a reinstall on the driver =)
Aug 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP 1350 Says theres a paper jam and won't clear. All lights on.
Try unplugging the printer from power, (Turned off of course) Wait 5 minutes, plug the printer back in. Now open the case like you're going to clear a paper jam, or change ink cartridges. Close the case. Press the Power On button of the printer.
Jun 05, 2009 | HP PSC 1350 All-In-One Thermal Printer
Hp officejet 6210 all-in-one
open that door, clear the jam , mostly paper trapped
close door and acknowledge with pressing button next to okay.
Should disappeasr.
If not still jammed.
If not, reset the printer.
Apr 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper jam cleared from back, but printer thinks it is still there
HI
please change the usb cable.. it will work.. and restalled that software cd also..
do it.........
Nov 18, 2008 | HP Photosmart 3310 Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
79 people viewed this question
old marine
old marine
