Question about Panasonic KX-T7730 Corded Phone
Programming names into phone
I need to change the names stored in our phones. How do I do it?
  • Anonymous May 14, 2008
    I can't reprgram the names to each extension. My owner's manuel is for the wrong model of phone.
FIRST OFF YOU EITHER MUST HAVE AN ADMIN TERMINAL OR BE ALLOWED INTO ADMIN PROGRAMMING VIA A HANDSET, NORMALLY A RECEPTION PHONE, OR THE FIRST EXTENSION NUMBER. ADMIN PASSWORD IS 1234
WILL BE IN YOUR MANUAL UNDER MANAGER PROGRAMMING, IS PROGRAM 004
APPROX PAGES 210-214
Posted on May 11, 2008
I need to change the name that displays on our Panasonic KX-DT343 phone system
On the main phone 9usually receptionist
1. Press Prog key
2. "**"
3. the user programming password (usually 1234)
4. "004"
5. Enter
6. enter the extension you want to change the name on
7. type out name (you must use the direction pad in the bottom right corner of your phone if you have 2 letters in a row that are on the same key)
8. press Auto Dial/Store button
9. lift hand set and hang up
Aug 19, 2012 | Panasonic KXDT343 Phone
How to change my display name Panasonic Phone KX-T7665
you will need to enetr system programming (only 1 phone on your system will allow this so try it all until 1 works)
Press PROG / PROGRAM /PAUSE
** 1234
enter 000 (try 001 002 003 etc until you see name )
enter you jack no (201 = 01 202 = 02 etc)
enter your name
press STORE
May 09, 2011 | Panasonic KX-T7425 Corded Phone
How do i change the name on the extention
Have your phone in Jack 01 of your PABX
Enter programming mode
Dial 604
NEXT
enter port number ie, 201 is 01, 202 is 02, etc
Enter name using the letters on your phone
Store
END
Feb 04, 2011 | Panasonic KX-T7730 Corded Phone
How to change extension name in panasonic kx-t7633
depending on programming restrictions:
at ext 101
1) press "PROG"
2) "**"
3) the user programming password (most likely "1234")
4) "004"
5) "ENTER"
6) enter the extension number you wish to change
7) txt out the name (you must use the direction pad in the bottom right corner of your phone if you have 2 letters in a row that are on the same key)
8) press the "AUTO DIAL/STORE" button
9) lift hand set and hang up
Jan 06, 2011 | Panasonic KX-T7630 Corded Phone
I can't changed name on my phone. please help me.
The extension names can be changed in admin programming from a predesignated programming phone. Typically this phone is the attendant phone as in ext 100 or ext 101.This phone needs to have an LCD screen.
1) Press <program>
2) Dial **1234(1234 is the default admin password)
3) Dial 004 for Ext name programming
4) Press <enter>
5) Dial extension number that you want to change name of as in 102
6) Enter name (20 characters or less )
7) Press <enter> to store
8) Press <end> or lift handset and return to cradle to end programming session
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Changing the name of user on panasonic phone
Press program *# and your system password (default is 1234). Enter 604 then press SP-PHONE. Keep on pressing SP-PHONE until you get to the desired extension number. Change the name and press AUTO DIAL / STORE. Press program to leave programming mode and you are done.
Mar 09, 2010 | Panasonic KX-T7730 Corded Phone
How do I change the user name on my KX-T7433 phone?
You need to find the receptionist or manager's phone. Press PROGRAM and dial **1234 that puts you into programming.
Now dial 004 and press the button above SP PHONE. Wow! It ought to say Jack 01-1 and Operator or the name of your receptionist.
If all the above works, I guess you'll have to post back for the next instruction, or try the FWD and CONF button for steps to programming. Nothing changes until you press STORE.
Carl
Jun 02, 2009 | Panasonic KX-T7433B Corded Phone
Setting the date
By programming, these are programs 000,001 and 002 for Date and Time, Speed Dial number, and Speed Dial Name.
Date and time programming is easy, I don't wish manual speed dial entry on my worst enemy. However, if you like a challenge, I'm going to give you a link to the programming manual.
http://public.carl.airpost.net/TDA/TDA_PTPM_32.pdf
Start with page 12, since you'll need it to get into programming.
Your key sequences begin on page 16. After you put the first 5 or 10 speed dial numbers and names in, you'll get the hang of entering names in the directory. Nothing changes until you press ENTER or STORE. Each speed dial number starts with a trunk access code (usually 9) as part of the number. In name entry, each time you press the key it changes a letter. In a TDA IIRC 7 presses of the 2 key will get you ABCabc2.
Carl
Mar 19, 2009 | Panasonic KX-T7630 Corded Phone
Change name that comes up on display phoned
Name programming requires access to system programming. If you go to the main phone and, without picking up the handset, press PROG and dial **1234 and ENTER, it will go into programming mode. Dial 004 and you are looking at the Ext Name screen. An ENTER at this point starts at 101 OPERATOR (default). Now just start pressing the letter keys and the right arrow to spell out the names. The keys press 7 times for ABCabc2. Punctuation and special characters are under the 1 and 0 keys and STORE or ENTER saves your work.
When I install my systems, I let everybody have access to the programming by class of service. You may be able to program from any phone in your system, it depends on the installer. The phone that rings when you dial "0" is probably the main phone if you can't program this from your own phone.
PROG exits programming.
Carl
Mar 11, 2009 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
157 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
