It says i have a paper jammed i have cleared it and pressed okay and it still says there is paper jammed
  • 1 more comment
  • mpasilon Jul 21, 2008
    i have the same problem. it says paper output slot -- the paper is jammed. clear the paper and press [OK]. the problem is that there's NO PAPER. the output tray is clear. i've reset the printer several times but to no avail. please help!
  • Sheikh Nisar
    Sheikh Nisar May 11, 2010
    what is the model
  • Sheikh Nisar
    What is the printer model number & when was it purchased
  • 40 Answers
Replace this officejet & switch deskjet
Posted on Jul 30, 2008
This is the most common issue for our HP 7700 series, ensure you have cleaned the gears from the rear duplexer, especially if the LCD readout displays or instructs you to remove the rear duplexer.
Someone posted instructions along with a photo of how to do this on Amazon.com product review of the 7780, it can be found at this link:
http://www.amazon.com/gp/customer-images/view-large-image.html?imageId=22103071
Posted on Jul 10, 2008
4 Suggested Answers
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
davedstone
  • 11 Answers
SOURCE: Paper Jam MX860
Double check as sometimes a small amount of paper will give this error message. If you are sure no paper is in the path/feeder, then unplug your printer from the ac supply for about 10mins (Logic reset) then plug back in and this should have this working again.
Posted on Sep 12, 2009
It says open door, clear carriage jam and then press okay to continue
This means you have a paper jammed inside of the printer, you need to open some of the access door to find and remove it. then you can press okay to continue printing.
Mar 01, 2011 | Office Equipment & Supplies
When i try to copy, paper goes into the printer and gets stuck mid way followed by error message "paper jam, clear ...". If i press the okay button again, the paper is ejected out.
Make sure the access panel/bar at the back of the printer is fitted in properly.
If you have removed it to clear a jam, it may not be seated properly.
Try to see if perhaps some paper is stuck in the rollers, or maybe your rollers are sticky
Use correct weight of paper - it does not really like card stock that much.
Make sure Junior has not shoved a pencil into the printer tray, etc.
Let the panel know if you were able to clear the jam and how you did it.
Dec 12, 2010 | HP PSC 1610 All-In-One Printer, Scanner...
Get error message on my HP Photosmart 7760 that "Print cartridge cradel stuck. Clear jam then press okay"...but there is no jam. :( Help...thanks.
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Jun 26, 2009 | HP PhotoSmart 7760 InkJet Printer
Hp officejet 6210 all-in-one
open that door, clear the jam , mostly paper trapped
close door and acknowledge with pressing button next to okay.
Should disappeasr.
If not still jammed.
If not, reset the printer.
Apr 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper Jam
No still jammed will contact the shop I purchased it from or ask the IT people I deal with at work if they have solution. Thanks
Dec 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper jam cleared from back, but printer thinks it is still there
HI
please change the usb cable.. it will work.. and restalled that software cd also..
do it.........
Nov 18, 2008 | HP Photosmart 3310 Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Naffed printer
Are there any small fragments of paper still in the paper path? I would inspect closely. Also on this printer, look at the back part of the printer and see if there is a little door that you can open to check and see if paper remains there. There is either paper there, or the paper feed sensor is blocked or damaged.
Mike
Apr 30, 2008 | Canon PIXMA MP460 All-In-One InkJet...
417 people viewed this question
jasbo
jasbo
