Question about ASUS Republic of Gamers Commando Motherboard
Ram Problem i have Asus Commando Mother board i am using 4 Gb DDR2 Ram (4 Single DDR2 Module) but bios show ram is 3 Gb i have lates bios version update but my problem is not solve i have tired solve this problem please give me a some solution
I have also check one by one ram but my problem is not solve
Posted on Apr 30, 2008
    Genius:
  • 2,785 Answers
Just check your ram one by one
What are maching ram for Intel D945GNT
Hello here is the homepage:
http://www.intel.com/support/motherboards/desktop/d945gnt/sb/CS-026631.htm
The board has four DIMM sockets and support the following memory features:
  • 1.8 V (only) DDR2 RAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • 4 GB maximum total system memory.
Windows xp does not support, more than 3 gb ram in the 32bit version.
Please take antistatic precautions, when working on the mainboard.
The drivers site is here if needed:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GNT
Good luck
Jan 24, 2013 | Intel D945GNT Motherboard
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
I upgraded my gategay gt-5428 computer memory 1 gb to 2 gb but still runs with i gb, what i did wrong?
Hello Erik,
Are you absolutely certain that the new module is compatible with your system? Go into the BIOS and see if it is recognized there.
Crucial shows that your computer takes DDR2 memory with support for DDR2 PC2-5300, DDR2 PC2-6400 speeds.
Make sure it is not ECC memory. ECC is not compatible.
If you are sure of the compatibility, I would try to install the old one by itself first and make sure the system boots. Then I would remove the old one and install the new one by itself. Try booting. If it doesn't work, you may have gotten a bad module. (It happens.)
Just FYI, here is the crucial link for your computer:
http://www.crucial.com/store/listparts.aspx?model=GT5428
Thanks for using Fixya.
Feb 27, 2011 | Gateway GT5428 PC Desktop
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
My system won't boot after installing a new 2 GB DDR2 RAM
Try cleaning it edge connector with soft eraser both side and dont try to touch the pin. If it doesn't help you got a defective one.
Apr 28, 2009 | ASUS M2N-MX Motherboard
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
I have an ASUS P5S899-VM motherboard and wish to install 2 x 1gb Samsung ddr PC3200 184 pin ram. Is this ram compatible with the motherboard? Many thanks, Colin Sinclair.
First you have to know the mother board supports the ram with ddr 1 and ddr2 . Now the new technology motherboard are supports only ddr2 ram and the ddr1 ram are consider as the older version. But ASuS P5S899-VM is contains the new technolgy of ram slot please see the manua or the mother board box. there you can see which it supports.please check it
Apr 28, 2008 | Computers & Internet
Upgraded Ram Issues
check the voltage on your new ram.
For ddr2 you need both slots filled.(this the memory I would use)
Make sure you put it in the right slots.
make sure that BIOs recognises each stick.
Let me know if these work for you.
Nov 30, 2007 | EliteGroup P4M800PRO-M478 Motherboard
ASUS Republic of Gamers Commando Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
