Question about Samsung Televison & Video
SOURCE: HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Posted on Apr 01, 2007
SOURCE: Samsung DLP HLN5065WX/XAA
krugie, get it replaced now or the lamp will burn up, be advised that they are expensive to get replaced, not an easy job to do, fix it now or pay much more later is the best advice I can give you, good luck, BMW Rider
Posted on Dec 28, 2007
SOURCE: Samsung LNT3253H is making a high-pitched noise
The high-pitched noise you are hearing is the color wheel. It is a very common problem in Samsungs.
Posted on Mar 23, 2008
SOURCE: Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
The problem is the dust that has hit the fans. The light and color wheel. In short DLP runs hot and if you have dust forget it! if you have ever sat in a presentation the projector is DLP. You can try to clean it out but there is not much you can do. I have a 61 inch RCA and it drives me nuts.
Posted on Jun 21, 2008
SOURCE: Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
Posted on May 18, 2009
Dec 20, 2016 | Samsung Televison & Video
Jan 08, 2016 | Televison & Video
Apr 02, 2012 | Samsung Televison & Video
Sep 16, 2010 | Samsung DLP HL-P5663W 56" TV
Aug 21, 2010 | Samsung Televison & Video
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Aug 13, 2009 | InFocus X1A DLP Slide Projector
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Dec 26, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Dec 26, 2008 | Televison & Video
Apr 18, 2018 | Samsung Televison & Video
74 people viewed this question
