Added new toner but light won't go off. Ricoh FT 3713
Yes, I had removed the tape strip. When the machine is turned on it cycles but then after it cycles, it stops and the red toner light is still on, and of course it will not work at all then. Any ideas??
  • 1,326 Answers
How about the green handle that locks the toner in place? If it is broken the copier will never add toner because it opens the bottle to let the toner out. How about did you try to run in sevice mode to do a "Force Toner" and see what happens.
Posted on May 08, 2008
The TD sensor got disconnected or is broken, the copier needs service because it's not detecting that it actually has enough toner inside to copy.
Posted on May 05, 2008
How do i fix problem Add Toner
The Ricoh has toner and developer. When the developer is depleted it can not get to the right density when toner is added so the machine keeps saying to add toner. You need to clean out the developer unit and put in new developer. Depending upon your model you may need to install a drum and blade too. Ricoh technicians are trained to dissemble the unit and just replace the parts needed instead of getting a whole drum/developer unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Oct 28, 2015 | Ricoh Office Equipment & Supplies
I added the toner in ricoh aficio mp 1500 but is still saying that there is no toner
how many copies on the machine? to find out press the user tools goto counter
if it is over 60,000 you will need a new PCU you may also need a new toner hopper (toner cartrage holder)
Jul 26, 2011 | Ricoh Aficio 2015 Copier
Toner empty message after replacing the toner Ricoh fax2210L
menu # 1934 menu search for new cartridge and then click yes yes ,turn power off and on.
Jun 18, 2009 | Ricoh FAX2210L Plain Paper Laser
Ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Mar 26, 2009 | Ricoh FT3713 Copier
Ricoh Toner for FT3313 and FT3713
When the developer is the same the toner is the same.The toner drops in to the developer,thus the toner must be the same.They just package it different to be a pain!
Nov 20, 2008 | Ricoh FT3713 Copier
Error codes
Try to check the fuser section.
- Check the Lamp
- Check Motor Assembly
Sep 12, 2008 | Ricoh FT5832 Copier
RICOH COPYING MACHINE MODEL 3713
Your copier may need developer if the cycle count is over 150,000 copies. Once that is added to the toner the Toner/Developer sensor should be calibrated and should work fine.
Sometimes the drum can create light copies if it was exposed to light from being out of the machine or leaving the door open too long on the side of the machine letting light in.
Aug 24, 2008 | Ricoh Office Equipment & Supplies
Ricoh Ft 3713 Toner light still on
try to enter 65 or 66 and let it free run for bout 20 copies...after that switch it off then on again...u can make it a try.
Jun 24, 2008 | Office Equipment & Supplies
Emptied toner waste and now I'm supposed to do an Sp 83 or Sm 83 to clear the counter?
ok, you need to enter service program as follows Press 7 key.Press 1 key.Hold down the stop/clear key until you see "." in the upper left corner of the display. Release the clear/stop key. press the clear/stop key again. Press the lighter key. The number "5" will now flash in the display.Enter "96" using the number keys.When you have enter the code,Press Print, cut copier off then on.
May 12, 2008 | Office Equipment & Supplies
Toner light will not go off
Did you remove the tape from the toner bottle when you installed it? It may just be looking to add toner back to the developer, to bring it back to the set level of toner? See if it stops
Apr 28, 2008 | Office Equipment & Supplies
83 people viewed this question
jasbo
jasbo
