Are you sure its U707?
Or you can go HERE and scroll to the bottom and click on use the global download center search (in fine print).
Make the slections and download your software/driver.
You can also download stuf into your phone without software (as long as the driver for the phone is installed). Go to START, right click, select Explore, scroll down to your phone, open the required folder and paste the songs into the folder.
If you find that the solution/answer I provided led you
to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
rating under my solution. I would be very grateful for your show of appreciation.
Should you have any further questions, please feel free to
post them here.
Cheers!
IrishDruid
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved."FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)"Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
