Question about Archos AV700 TV Digital Media Player
Archos av700 tv output to vga lcd screen
1. Is there such a thing as a an adapter which connects to the minijack output port of the archos av700tv and goes to a vga connector for video playback on an lcd monitor .
Hi
If you buy an archos travel cable/kit it has an adapter whitch will connect to your tv
You can find it on EBAY very cheap
regards
wilf
Posted on May 19, 2008
Dc power input for av700
This isn't really a good answer but there was an external charger available at one time that was fairly inexpensive. The one I got came from China. http://www.newmp3technology.com/multibox2-700.htm
Jan 01, 2013 | Archos AV 700 160-Hours Video Recorder
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Are there any updates for the AV700 tv
go to link # 1 and scroll down to Operation in green , click on How do i update the firmware on the AV700 TV? read it . this is the firmware update link # 2 KEY NOTE you might be able to find the problem you have on the first link
# 1 http://www.archos.com/support/support_tech/faqs/en/faq_AV700TV.html?country=us&lang=en
# 2 http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Sep 24, 2010 | Archos AV700 TV Digital Media Player
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
MININ DV TO ARCHOS
Initially, it would work better if you can provide the specific model numbers of the Sony Mini DV Cam and the Archos. Assuming all things even, most DV cameras have an analog A/V video OUT, in turn some Archos with recording capability have an analog A/V video IN. If this were the case, then it would be a matter of getting the right connectors/plugs + cable and/or adapter/interface.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Archos AV700 Digital Media Player
My archos av700 has a dark screen
Managed to resolve my dark screen issue. It is a little weird and not sure which combination actually got it going but it works. I firstly connected the TV POD unit to the AV700 and used the remote and no joy. With the TV POD unit still connected, I fiddled with the battery latch switch a few times and VOILA! - the screen came back to life and all is now good.
I hope it is as easy as that for all of you....
Apr 26, 2008 | Archos AV700 Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Archos AV700 TV Digital Media Player Logo
173 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
