FixYa.com
Tags:
Hotpoint Aquarius WD63 Front Load All-in-One Washer / Dryer
Knocking on WM63 (by 2 users)
posted by marc marc on Apr 30, 2008
Hi there, i also have a WM 63 that knocks badly on full spin, and i think that the suspension is worn. the drum is very easy to rock and push up and down if you take the lid off and push gently with your hand. the concrete blocks are solid and i have replaced the springs, but it hasn't helped much.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by anemolihp, posted on Jun 29, 2008
Loud knocking when in fast spin mode
Solution #1
posted on Jun 19, 2008
Not Rated (0)
Richie_asg1
Rank:Guru Guru
Rating: 86%, 146 votes
Hi there!
Yes , you need new dampers for it.
These are easy to fit from the rear. Look at online parts stores under your model, and you should get them delivered within a week.
Check also that any foam bumpers are still stuck on the sides.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
Hotpoint Aquarius WD63 Front Load All-in-One...
Hotpoint Aquarius wd640p
washes ok, but on dryer cycle... Answer This...
MACHINE LANGUAGE PROGRAMING
solve machine language with an... Answer This...
HI WT540 HOTPOINT
i have hotpoint wt540 washing... Answer This...
hotpoint aquaris wma32
when i put machine on it fills... Answer This...
Hotpoint wd440
When I start the machine the on... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
