Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Cannot change pc's date and time
Even logged on with a SysAdmin (full priv set) account, I am unable to change the Date and Time properties on any of my XP client work stations.
I am getting the following pop up window;
Date and Time Properties.
You do not have the proper privilege level to change the System TIme.
I would be very appreciative of any assistance in clearing this problem.
Thank you very kindly,
kie..:)
    Genius:
  • 2,785 Answers
Plz scan your pc for viruses by disabling the system restore
Posted on Apr 30, 2008
What I can I do, when my computer is untrusted?
Check your time of the pc first. if its ok, then update your browser.
May 22, 2014 | Yahoo Mail
Need to change date and time on my Dell pc laptop
Save the time and date in BIOS. Replace the CMOS battery if it still does not save.
Jan 09, 2013 | Dell GX745 Refurbished Desktop PC
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
How do I set the date in the right corner of my computer screen
Just double click the clock on the lower right corner of your screen. It will give you the option to edit the date and time of your machine. If it prevents you from changing the date, that means you need an administrator account to edit the date.
Regards
Sep 12, 2011 | Dell Dimension 4700 PC Desktop
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
I can't surf gmail.com.there is a certificate error
Certificate errors are typically caused by an incorrect date or time in your operating system's calendar.
To set your Date and Time Properties in Windows, please follow these steps:
  1. Double-click the time in your taskbar to open the Date & Time Properties menu.
  2. From the Date & Time tab, verify that the appropriate month, day, and year are selected.
  3. Click Apply to save any changes you make.
  4. From the Time Zone tab, verify that your time zone is selected. If the time zone in which you are located is not displayed, select your time zone from the drop-down menu.
  5. Verify that the box beside Automatically adjust clock for daylight savings changes is checked.
  6. Click OK.
  7. Close all your browser windows, restart your browser and try logging in again.
Mar 28, 2011 | Google Gmail
My laptop sum time log on and sum time does not log on
Depending on the type of operating system that you have, you may have an issue with a user account. One of the first steps is to ensure that your user accounts have the proper passwords and if it is not a password related issue, then you may have a faulty user account.
In the case of a faulty user account,you will have to log in as the administrative account on the computer and delet/recreate the user account that has problems.
If this is happening and there is no other accounts but the administrative account on the computer, then you will have to possibly do a restoral, meaning have the computer go back to a earlier date ( under my computer - right click and go to properties, then click the tab that says (restore or system restore) and restore to an earlier date.
Jan 01, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Windows Live messenger Error : 80048820
If you are receiving error 80048820 when trying to sign into Windows Live Messenger you should also get an extended error code. If this extended error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
May 29, 2009 | Microsoft Windows Live Messanger
On my LCD the date shows o4/24,how I can change to the right date on the user's guide I cannot find thedate/time.
Double click on the time. The Date and Time Properties box should open and you will be able to set it.
Apr 23, 2008 | Computers & Internet
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
220 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
