Question about Vacuums
Keep replacing belt that drives brusher but keeps breaking. When feel belt driver rod it is superheated.....could it be melting into the stretched belt causing it to weaken?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559226
Generic problem for all Vacuums
Posted by andy78billy on Apr 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on the brand name and model # it is my opinion that it is not the belt, it may be that your brushroll is bound up with thread, hair, dirt, etc., and is not spinning well – place the brushroll on end and try to spin it, if it does not spin freely, then you are bound up, try to clean it up and lubricate by using one drop of oil and then wipe off the excess, you don’t want the oil to hit your carpet, if that does not work replace the brush and the new belt, am average flat belt change is every 4 to 6 months – also you may have the wrong size belt of which would cause the to burn up fast. Always use the genuine vacuum belts when replacing.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 30, 2008
Why does the belt on my dirt devil jaguar vacuum model # UD70230 keep falling off?
The belt may have stretched. Some of the cheap substitutes either stretch or break early on.
Jul 25, 2017 | Dirt Devil Vacuums
I keep replacing the belt and keeps melting and breaks. what do i need to do? everything else is working, the little piece of metal that hooks on the belt gets too hot and melt the belt
i think your talking about the motor spindel,,(the little metal bit?) if the motor is that hot its going to burn out soon, check that the brush is free to turn if its tight free it off its full of grit or fluff also check that the motor turns freely
Dec 02, 2010 | Dirt Devil M084600 Dynamite Bagless...
My dogs hair often accumulates in the spinning rod
Try spinning it by hand with no belt. If it is tight, dismantle the bearings at the end and clean out the hair . If it is loose then the problem is likely that your belt has stretched, Buy 2 genuine belts and keep a spare on hand. For best cleaning results , replace every 3- 4 months ( broken or not) , if you have a lot of pet hair
Nov 08, 2009 | Royal 5300 Upright Vacuum
The belt keeps coming off
A belt will come off for several reasons.:
Wrong size or stretched... should be changed ever 3-6 months.
Misaligned pulley on brush or idler pulley on 2 belt unit
Misaligned motor.. this is rare
Put in a fresh matching genuine belt and keep a spare handy. Belts stretch and slip long before they break
Nov 06, 2009 | Panasonic Vacuums
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt keeps breaking
in some cases when you by a belt from the brand stores the belts are not always to spec's. for example: you pick out the belt that's for your machine you go home and put it on and not even 5 to 10 mins. the belt breaks, thats because the spec's or not at the company's spec's and they break fast. take the same belt from the company and you will notice that the belt can be stretched alot more and is easier to put on. if you put on a new belt and it still breaks, first see if the brush or agitator can move freely. if not then the agitator needs to be replaced. ( fyi : the agitator end caps need to be taken off and cleaned for dirt or hair that gets twisted in there)
Aug 02, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Why are new belts breaking immediately?
Could be the brush has resistance..
While the new belt is in place - spin the brush by hand.. The brush should spin reasonably freely..
If not - take the brush out and inspect it.. Be sure the ends are not jammed and you can snin them easily.. If not - replace the brush..
PS - the belt goes in one way.. If inside-out - it will not last as long..
Directions on packageing..
Hope this helps !!
rate mehood ;o)
Jul 14, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
The belt keeps burning and breaking within 2 seconds of use
the rod should have a plastic runner wheel on it to hold the belt in place and reduce friction
Jun 07, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Why does the belt keep breaking on my kirby
Odds are that the problem is not with the belt or the pulley, but with an agitator (rotating brush) that isn't turning freely. Remove the rotating brush and check to see that it spins freely. If not, you would either need to disassemble it (removing the end caps) to see if removing whatever hair / diebris is stuck between the end caps and the body of the agitator, and if that doesn't cause free rotation, then it means your agitator bearings are likely bad which means you will need to replace the agitator assembly.
May 06, 2009 | Kirby G6 Bagged Upright Vacuum
Hoover wind tunnel cyclonic U5780900 1 year old. brush will not turn. too much slack in vbelt when in carpet position. Belt is good
Well, the V belt is normally fairly slack until the handle is dropped below 45 degrees, which is when the belt tensioner assembly drops into place. If turning the brushroll by hand when the vacuum is in this position fails to rotate the self propel pulley, the tensioner is not functioning properly and will need to be replaced.
Also ensure that the brushroll can spin freely by hand, as these have a tendency to melt at the ends and seize the brushroll. I have also seen the groove that the v belt fits into melt itself out of round, which can cause the same symptom as you're describing.
Keep in mind as well that while the rubber belt may appear to be ok, it does have to be replaced every 3-6 months whether it breaks or not. Even though it hasn't broken, if you were to hold it up against a new belt, you would see that the old one has stretched significantly: which can decrease the machine's ability to rotate the self-propel transmission pulley and, in turn; the brushroll.
Feel free to contact me with any further questions.
-R
Oct 01, 2008 | Hoover Vacuums
Vacuums Logo
290 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
