Question about HP 5590 ScanJet Flatbed Scanner
Hp scanjet 5590 error in comunication when trying to use the scan to buttons on the scanner
  • sproket Apr 30, 2008
    it woks fine with the hp software and it is only since there has been windows updates put onto the pc yesterday that this has happened.
  • Anonymous Mar 13, 2014
    scanner is not seen by the computer
I downloaded the following files from HP's website
setup_full_5590
setup_emc_5590
col10862
cit207355-hpcom-patch-v8
hpinstantshare
and followed the procedure that i found on the web at hppt://hpanswers.blogspot.com/2008/03/unexpected-internal-error-has-occurred.html
wich give full instructions on how to cleanly remove the hp software and what files you need to run to help fix the problem.
this is a fix but it is has not got my scanner working the way that it used to but it is working a lot better that it was.
Thanks
Sproket
Posted on May 01, 2008
Hp scanjet 5590 failed to create empty document
HP SCANJET 5590 ERROR "failed to create empty document"
Aug 18, 2010 | HP Scanjet 5590 Flatbed Scanner
HP Solution Center does not recognize the scanner anymore... We are operating on a Windows 7 system... the drivers had to be downloaded from the internet because the cd that came with the printer was for...
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
Feb 02, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Scanjet 5590 Lamp Error "Bad or fading lamp (error -4430)" Fixable? Can I do it? Best source to purchase?
From HP forums:
The first thing I would do is to make sure your TMA is properly attached. Next, make sure your software is up to date and that any applicable patches have been applied.
Next, what OS are you using? What application are you trying to use to scan with? Can you scan from any other application such as word or another graphics program?
Oct 06, 2009 | HP Scanjet 5590 Flatbed Scanner
Scanjet 5590 wont scan straight images
I have the same problem. It's very frustrating!
Sep 14, 2009 | HP Scanjet 5590 Flatbed Scanner
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
Apr 27, 2009 | HP 5590 ScanJet Flatbed Scanner
I have an HP flatbed scanner 5590 - "lamp error"
I had the same problem and I finally unplugged for a few days
and when I replugged it worked !?
Nov 30, 2008 | HP Scanjet 5590 Flatbed Scanner
HP ScanJet 5590 ADF doesn't engage
cannot possible to install in vista using the CD of scanjet 5590
Apr 16, 2008 | HP 5590 ScanJet Flatbed Scanner
Hp director
uninstall and remove all the icons from your PC first than reinstall the driver from CD and run complete setup it works.
Feb 18, 2008 | HP 5590 ScanJet Flatbed Scanner
HP 5590 ScanJet Flatbed Scanner Logo
884 people viewed this question
Ben Johnson
