Hotpoint WD129 Wash programme stuck
My Hotpoint WD129 does not go past the wash cycle of the programme it just sits there and keeps on washing in an endless loop, how can I fix this?
Is there a reset I can do to?
I have a Hotpoint WM62 that gets stuck on the wash cycle. For some time the hot inlet was not connected. Now it is connected but the programme gets stuck on the wash cycle
I am having the same problem with my widl126 washer.
ant help?
Posted on Sep 15, 2010
Cycle wont move on withhotpoint 220
check the heater once its filled it will stay in wash until it heats to the correct temperature so if the heater has failed it will stick in programme
Feb 27, 2014 | Hotpoint Washing Machines
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
I have a Hotpoint BWD 129 and it's stuck on the wash cycle.
Hi this is abhishek welcome to fixya
its actually a timer problem,,,,,,better to fix it
thank u....
May 03, 2009 | Washing Machines
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Hotpoint first edition takes in water but does not wash
Could possibly be a broken drive belt to the motor or motor brushes may need replacing.
Oct 28, 2008 | Hotpoint First Edition FEW12 Front Load...
its possable not pumping out water when it should, is it???
Nov 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
419 people viewed this question
Top Washing Machines Experts
