Question about NEC VT676 Multimedia Projector
Menu I bought a vt676 second hand. I have this problem: It seems that it was used as fasten up side down to the seeling. No I see the menu up side down. How can I solve this?
  • Anonymous Apr 30, 2008
    sinA sin2A +SIN3A SIN6A /sinAcos2A+SIN3A COS6A
  • 563 Answers
Hi paulveldt
Very easy ! Simply go into the menu and look for the subfolder that will either read Mirror or Flip Image. Scroll down to it and press left or right until the image is back to normal.
A mountable Projector can project flat fronted ( on a table ) upside down ( on the ceiling ) rear ( from behind - on a rear projection screen ) and upside down from behind ( from the ceiling onto a rear projection screen )
This should do the trick !
Thanks for using Fixya !
Posted on Apr 30, 2008
  • Marnus Jacobs
    Marnus Jacobs Apr 30, 2008
    Hi Paul Veldt
    Did the solution provided not work ?
How to replace blades on a hand held power devil planer (old version)
Try this.
Loosen the fastening bolts Loosen the three bolts that secure the blade.
2. Remove the blade
Now you can use a screwdriver to begin sliding the blade out of its slot. Grab the blade carefully and slide it out the rest of the way.
3. Repeat the process on the reverse side
Now turn the planer's drum around to the other side and repeat the process on the second blade.
4. Install the new blade
Now you can install the new blades. Notice the blades have a notch on them that aligns with the slot on the drum. Align the notch and slide the blade into place.
Loosely tighten the outer two nuts, but don't tighten them completely yet.
5. Align the blade
Make sure the blade is centered so it won't rub against either side of the planer. Once the blade is centered you can fasten the bolts down completely.
6. Repeat the process on the reverse side
Now rotate the drum and install the new blade on the other side.
Jul 22, 2017 | Crafts & Hobbies
Uneven push arm?
If a button latch fails to engage, it often is due to a weak spring. Some wiggling action may get it to pop out; otherwise the part inside the handle will have to be accessed which could prove to be virtually impossible.
Jan 19, 2014 | Bugaboo Baby Gear
What does a solid red status light on a NEC VT676
This could be a number of things. When I encountered this problem it was simply a burned out lamp. If you have not checked that make sure you do that first. Also there is a safety feature on the projectors that will not let you turn the projector on until the lamp cover is back in place. You may also want to ensure that the filter door is securely in place. After you have done this try to power up the projector (it will take a few seconds for the lamp to warm up.) If the projector starts up, go to the menu and clear the lamp hours. These projectors have lamp life's that will expire after a certain amount of time, irregardless of the functionality of the bulb. Hope this helps you out. :)
Apr 13, 2011 | NEC VT676 Multimedia Projector
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
If the unit will not power up it sounds like you may have tripped the lamp timer. You will need the remote plug the unit in and hold down the menu button on the remote for 10 seconds. The red light should go off and the unit should fire up.
Thanks Projector Guy
Apr 21, 2010 | NEC VT676 Multimedia Projector
Mar 02, 2010 | NEC VT676 Multimedia Projector
Screen cuts off image
To see the button on the right hand side of this monitor you will need to shine a really bright light on it, but the buttons from top to bottom are: 1, up-arrrow, down-arrow, and 2.
  1. On the side of the monitor press the 1 button to activate the menu.
  2. A configuration menu for the monitor will appear; from that menu highlight the "Input Select" menu item using the up and down buttons on the monitor; when you have the item high-lighted, press the 2 key.
  3. A new menu will appear, and then you can select the menu item called HDMI on the left and PC waaay over on the right. Select this menu item with the up and down arrows and when it is selected,
  4. And press 2 like you did in the previous step.
Apparently there's some sort of a strange difference between using this monitor as a "video monitor" and using it with a computer.
Nov 02, 2009 | ViewSonic VX2433WM 23.6" Monitor
Need to access service menu/mode
To access the Zenith service menu: Hold down the menu button on the remote control until the menu disappears. Then type in 9-8-7-6-enter. This should do the trick. Be careful what setting you change. I would recommend writing them down before you change any. Hope this helps.
Apr 30, 2009 | Zenith IQC50H95W 50" Rear Projection...
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
NEC VT676 Multimedia Projector Logo
300 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
