There are two possibilities. The first is the most probable. From the foot shift lever, follow the shifter rod back to the shift lever on the transmission. The shift levers get worn and no longer shift the transmission like they should. You'll have to remove the outer and inner primary to get to the lever to replace it. If the splines on shifter pawl shaft are worn out, you'll have to pull the transmission down to replace the shifiter pawl shaft.
The other problem is that the shfiter pawl is broken and not rolling the shifter drum far enough for it to engage in the detent slots for the gears. To fix this is again, a teardown of the transmission.
Good luck
Steve
