Internet pages not in widescreen
Internet pages displayed in middle of widescreen 5inch blank gap to left and right of internet pages
  • 558 Answers
Display resolution incorrect go to display settings and resize the screen until it is wide as the monitor, 5 inches thats allot of blank space...
Posted on May 11, 2008
How do i remove web search as my home page
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. Click the General tab.
  4. In the Address box, type the Web page address that you want for your home page.
    NOTE: If you want the page that you are currently viewing in Internet Explorer to be your home page, click Use Current.
  5. Click OK.
FOR FIRE FOX
  • At the top of the Firefox windowOn the menu bar, click on the ToolsFirefox menu (Tools menu in Windows XP), and then click OptionsFirefoxEdit menu, and select Options...Preferences...
  • Select the General panel (Main panel in Firefox 3.5).
    • In the Startup box click the drop-down menu next to "When Firefox starts:" and select what Firefox should display when it starts up.
    • Show my home page - Displays the home page (or home pages of course).
  • Show a blank page - Displays a blank page (this loads fast - no waiting for lots of tabs to load).
  • Show my windows and tabs from last time - Opens the pages you were visiting the last time you used Firefox so you can continue right where you left off. Click OK to close the Options windowClick Close to close the Preferences windowClose the Preferences window .
kindly rate this solution
thanks and regards
Feb 14, 2011 | Computers & Internet
Page: about blank
if you opened up a page from Internet Explorer or Mozilla firefox, then it has a display which says, "about blank", try to click tools on the upper left corner and scroll down to options and click then on the main page change the Home page to your desired site. click below "apply" or "ok". try it by executing exit and then open again the page.
Thanks
Dec 16, 2009 | Office Equipment & Supplies
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
Orkut page left blank after signing in
Clear your cache & cookies from the browser & then reload the page. Easy.
This was a problem I had for Gmail & Orkut. But the above solution does solves.
Jul 01, 2009 | Microsoft Computers & Internet
Dell blank page keeps appearing how can I correct
Sounds like your screen saver is set to a very short period, like 1 minute or less.
Try this, Right-Click on the Desktop Wallpaper (behind the icon on the desktop, NOT on an icon), then select Properties.
When that dialog window opens, Left Click on the Screen Saver tab at the top of the window.
This will select that page of options.
On the Screen Saver page, about in the middle of the page you should see
Wait: (and a box with a number in it) minutes (check box) On resume, password protect.
I suspect that the number in the box is small, like 1 or 2, try changing this to something like 15 minutes.
Now this solution assumes your on Windows XP, this is done slightly different on Vista, please inform me if this doesnt help you!
Hope this helps you, Good Luck :)
Apr 15, 2009 | Dell Studio 1737 Laptop
Left side and right side are blury.
With projection sets, there is typically several settings for which you can display an output. You probably have a "wide" or "stretch" as a setting for the tv. What you want is normal, or some setting which doesn't result in a stretch. Widescreen projection tv's try to stretch 4:3 output into the widescreen setting, but usually this just results in the middle being in focus, and the outer 20% to be stretched on each side, bluring the edges.
Try to manipulate as many "tv settings" as possible. For most sets this is only available with the original remote. If you don't have the original remote, changing these settings could prove difficult.
Apr 05, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
I have a TX32PM11C 32"
You have to turn off the "automatic", so the TV will not automatically show you what it wants you to see. Then, if you select 16:9 , you will see true widescreen.
Since you cannot physically change the size or shape of your TV, the picture itself will be black on the top and bottom. Since not all programs are widescreen, sometimes the sides will be black. You can try the other sizes to see which works best for you.
Apr 25, 2017 | Panasonic Televison & Video
Computers & Internet Logo
544 people viewed this question
David Payne
David Payne
