I turned my laptop on because I wanted to watch Dvds on it. I put a normal Dvd disc in it, and opened Windows Media Player. It just went frozen. Then I minimised it and opened up another Dvd Program called Power Play. This had the same problem. It was frozen for about 5 minutes. Then I pressed the off button and it took for ages to turn off. I continued pressing the Power button, but the blue light kept on showing, and the fan was still going. I decided to leave it alone. After 45 minutes I came back, and the light and sound was gone. So when I tried to turn it back on, it wouldn't even start again. Please help!!
The problem first started by the laptop freezing after 5 min of startup.After some days i tried putting it on but it won't come turn on.The led power and battery indicator will not come up until i remove and re-insert the battery.When i do this,the power led and the charging indicator comes up but the laptop wont turn on when i hit the power button.How can i fix this?
Basically I get fraustrated with it and remove and replace the battery and the same with the power cable trying various different combinations while trying the power button. Works for me, I also give it a good few whacks sometimes, I don't think it helps but certainly makes me feel better.
OH, I'm told it's a loose connection between the power board and the mother board, It's an easy fix you just need to unscrew the back, remove the connection and re-connect, I haven't got around to getting a long enough screw driver yet as a couple of the screws are set in deep holes.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Post a New problem for Toshiba Satellite Pro 6000 and 6100
Email this problem
Can you Help with these CD ROM Drives problems?
Blue Vertical Line on my laptop...
hard drive password solution
Toshiba satelite
my dvd and video card
