Question about JVC AV-36950 TV
Picture blacks out after a few seconds after turning on the tv
My JVC LT-32X576 lcd tv picture goes black after a few seconds after the tv is turned on. The audio still works. Before the picture black out occurred, the picture had occasionally gotten a pik/purple tinge in previous weeks. The tv is 2 years old.
Thanks for your help
START BUTTON FLASHING CANNOT MANUALLY TURNON
  • puzzledpam Jul 24, 2008
    JVC lcd tv turns on ok, then after a few minutes the picture disappears. Sound is perfect.
4 Suggested Answers
snakehead
  • 1070 Answers
SOURCE: JVC TV Issue
the problem with your tv is in the video circuit the ic or transistor needs to be replaced there is a box on the fixya home page just enter your zip code in the box and it will help you locate a repairman in your area.good luck.
Posted on Apr 14, 2007
SOURCE: TV: bright line across black screen for several hours.
Re: bevbreaux posted Mar 8 '09--thank you, for solutions from
dogey & mchelec--not yet tried. Dogey said it would be helpful to have model number, which is: JVC AV 20-CM 5.
Problem is bright horizontal line across black screen.
Posted on Mar 29, 2009
  • 25 Answers
SOURCE: I have a black retangular box in the middle of the picture screen
i had the same problem with a Sanyo tv, was ready to trash it and a friend told me how to fix it.i went to the tv menu (not cable or satellite menu) and from the settings list chose CLOSED CAPTION . i had inadvertantly made a change there which left me with a black text box and very little viewing area. i just had to make sure all of the options for CC were OFF. hope this helps
Posted on May 27, 2009
  • 26 Answers
SOURCE: A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Posted on Aug 20, 2009
Sony Bravia flat screen TV when turned on has black screen. Green light on the bottom is lite up, electric plug is plugged into house socket, no picture only black screen.
If audio is OK, the fault is with its backlight section. If audio too is absent, the fault is with its digital main board. If you wish to get more details visit the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Jan 08, 2017 | Sony Televison & Video
How do i fix black spots on my LG plasma tv. model 50pj350ub
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 08, 2017 | LG 50PJ350 50 HDTVReady Plasma TV
I have pioneer plasma tv about 6 years old. I turned the power on, sound but no picture. Do you think it is worth fixing?
no
plasma tv units consume considerable power and the latest led units don't so for the extra cost of a new unit , there will be a power saving over the years
Jan 08, 2017 | Pioneer Televison & Video
Sharp lcd tv. Grn lite flashing, reset by unplug, vol + ch - , plug in. Tv came back on, after few mins screen goes blk, have sound. turn off and on picture back for few minutes, goes blk, snd ok.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 07, 2017 | Sharp Televison & Video
I have sound but no picture on my tv
This is a popular question. Most of the time you either need to make sure all connections are not loose or just need to turn off your tv and receiver and unplug. Wait for 1 minute then reboot.
I recommend this short video as it walks you through some diagnostics for other possible problems.
Repair TV With Sound But No Picture
Nov 24, 2015 | Luxor Televison & Video
Sony bravia shuts off
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 30, 2014 | Televison & Video
When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
May 26, 2014 | Televison & Video
How do i fix my elonex tv
switch off.wait for 5 mins.
press & hold power button till it turns on then off.
ifno luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
May 04, 2014 | Televison & Video
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
Red exclamation point on verizon set top box
How to reset your Set Top Box to fix common problems FiOS TV Residential...
Resetting your Router and Set-Top Box can resolve a variety of issues such as:
  • Missing Interactive Media Guide (IMG) or On Demand menu
  • Unresponsive Set-Top Box
  • DVR recording problems
If you are having any of these issues, you may need to reset your Router and Set-Top Box. Will resetting my Set-Top Box erase the selections I have programmed into my remote?
No, all settings and selections you've entered such as device codes, favorite channels, and recent On Demand selections are saved and available after resetting your Set-Top Box.
Always reset your Router first and then check to see if that resolves the issue. Resetting your router may be all that is needed.
Important note about your router To avoid problems with your FiOS TV service, make sure your router is plugged in and turned on at all times. Even if you are not currently using the Internet, your router still needs be turned on so that FiOS TV can function properly.
To manually reset your router:
  1. Unplug the power cord to your Router for 15 seconds and then plug it back into the electrical outlet.
  2. Wait 30 seconds and then check to see if this resolves the trouble. If you still have the problem, follow the steps below to reset your Set-Top Box.
To manually reset your Set-Top Box:
  1. Unplug the power cord to your Set-Top Box from the electrical outlet for 15 seconds and then plug it back in.
    Note: Don't confuse the power cord that provides electricity to your Set-Top Box with the coaxial cable that is connected to the back of your Set-Top Box. Unplugging the coaxial cable will not reset your Set-Top Box. Since many issues can occur if your coaxial cable is not securely fastened, now would be a good time to check to ensure all connections are securely connected.
  2. Wait for the time to appear on the front of the Set-Top Box, then power it on.
  3. Wait several minutes while the Interactive Media Guide updates.
  4. Check to see if this resolves the trouble. If you still have the problem, your Set-Top Box may need to be re-initialized. Contact the Fiber Solutions Customer Support for further assistance.
I have to reset my Set-Top Box frequently, is this normal?
No, if you routinely have to reset your Set-Top Box more than three times a week, it is likely there is an issue with your Set-Top Box that needs to be resolved. Contact the Fiber Solutions Customer Support for further assistance.
also you can call for tech support at Dial 1-800-VERIZON (1-800-837-4966)
Oct 05, 2012 | Televison & Video
JVC AV-36950 TV Logo
204 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
