Question about Samsung SCX-4216F All-In-One Laser Printer
Over heat my samsung 4216f showing over heat detected and lamp in the fuser unit is not getting on
  • 161 Answers
You have a bad fuser unit. Since the copier does not complete the self-test process, the lamp does not turn on.
Posted on May 29, 2008
I have a Temp Pb on my 4216F MFP, and i found an alarm: Open Heat Error in diag mode (#1931).
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Nov 20, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216f prints line of numbers and letters at page bo
Uninstall your printer driver.Install again your printer driver.If it problem your printer properties.Second thinks,if it problem arise heater or fuser unite please change heat roller,then fix this problem.
Feb 23, 2010 | Office Equipment & Supplies
Samsung sf5100 fax shows "fuser error" and I cannot receive faxes but can send ok
The fuser unit will need to be replaced. It's possible that the heat lamp or thermostat of the fuser has failed, but getting those individual items could be difficult. The fuser unit should still be available from a Samsung repair center. Search on line for your nearest authorized dealer. You will continue to be able to send regardless of the fuser.
Jul 07, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung scx-4216f
may be fuser unit thermostat problem. if it is low heat eror change it.
Jan 12, 2009 | Kyocera KM-1510 Copier
Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Nov 04, 2008 | Samsung CLP-510 Laser Printer
Open heat error
when i on my scx-4216 samsung laser printer it show on screen open heat error on display screen
tell me the solution
Apr 17, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsubg scx-4216f
sounds like a problem with your fuser allso called a fixing unit.
Feb 27, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung scx4216
Open heat error, you have a fuser problem, replace fuser. Fuser consists of Upperheat roller, lower heat roller, exit claws/rollers, and a heating circuit with a lamp, thermal temp sensor (thermistor) and a thermal fuse/cutout.
You could measuring fuser removed from machine, checking lamp etc for open circuit, thermistor should be neither short or open circuit.
These days we dont, we just change assembly due to it being a common constantly wearing part, and if for example I pull it apart, fix the lamp, put it together then soon enough I will need to pull it apart again to fix worn roller etc.
I could give you the part number ... JC81-01690A but dont use it, cause that part is for 220volt cause thats what we use in Oz, so contact Samsung and ask for dealer in your country who can supply you.
P.S. Fuser is the Hot bit (180 deg c) at back near paper exit that bonds(melts) the print into the paper.
Nov 14, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
88 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
