Question about JVC LT-32X576 32 in. LCD Television
36" jvc tv start button flashing
Start button flashing, can not power on manually. pls help
  • dturner73 Sep 11, 2008
    I have the same problem. TV was working the night before but now the blue light just flashes. Any suggestions???
  • derekmance May 11, 2010
    Mine dosnt flash
You must hit the input button on the side of the TV until your input is detected.
Posted on Dec 25, 2008
Power button flashes blue continously and TV will not turn on.
The lamp is probably gone. Part # TS-CL110U. Easy to change yourself.
Apr 15, 2009 | JVC HD-56G787 Television
Got a tv from a friend wit v-chip can find out the code it a jvc tv plz help
It looks like a power interruption resets the code (according to the JVC manual). It then defaults back to "0000"
Page 36 on THIS manual explains the procedure.
Apr 13, 2009 | JVC Televison & Video
JVC 36
Hi Dave: "My JVC 36" TV will not power on and has a blinking power light."
That means that the protection circuit has started because a fault had been detected.
If this happened after a power surge it is likely a faulty PSU board.
Try first leaving the set unplugged from power outlet for few hours, this will drain power, reset the protector, and fix problem related to accumulation of electrostatic charges on PSU power capacitors.
If unplugging does not work, that means that there is an internal fault.
If this happened after a power problem of some kind, that means that probably one of the capacitors on powr board had blown, and must be replaced.
The TV must be tested by a technician to find the fault.
Jan 05, 2009 | JVC AV-36D303 36" TV
The digital clock on my 30"JVC is showing in the bottom of screen
The menu screen does not function the display. Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes or more and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results. Reference the user guide below for the display button.
neww.gif JVC AV-36D503 36" TV - User Guide (page #43)
Dec 20, 2008 | JVC AV-36P902 36" TV
My JVC AV-36P902 is turning on and off by itself
power supply problems maybe the regulator
Aug 06, 2008 | JVC AV-36P902 36" TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
Please Help Fix My TV - Toshiba 36" Model No. CF36G55
No, in answer to your question, I have not solved this problem! I am waiting to hear from someone on your site.
Thank you.
Apr 12, 2008 | Televison & Video
Jvc tv
You need to check the horizontal output transistor first for a short,ift he transistor is good check the diodes and low value resistors of the secondary of the flyback(output trasformer),if all those are ok check the crt board,it has low value resistor for the g2 voltage,if ok you need to go back to power supply and check for a short from each one of the diodes to ground for a posiblwe short.Be careful when measuring voltages and use the correct ground.
Oct 01, 2006 | JVC AV-36F702 36" TV
JVC LT-32X576 32 in. LCD Television Logo
170 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
