Question about Canon Office Equipment & Supplies
Scan with mp 530 - Canon Office Equipment & Supplies
Update drivers. XP drivers won't function with Vista.(Like most things.)
Posted on May 01, 2008
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Printer will not turn on. power supply voltages
You should verify that your voltmeter is reading correctly. Check it against an fresh flashlight cell--it should read about 1.56 to nearly 1.6 volts. You apparently don't have an overload problem. Usually, only one voltage is the reference voltage for the voltage regulator (+5 volt?). It is entirely possible that the two supplies have a common failure. Make sure they have not been set for 220 volt AC supply.
Mar 01, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How to set the date and time
You can set the date and time on the machine:
1) Press <Fax>
2) Press <Menu>
3) Use [<] or [>] to get to "User Settings"
4) Use the number keys to enter the date (only use the last two digits of the year) and time (in 24 hr format)
5) Press <OK>
6) Press <Stop/Reset>
Your MP 530 should obtain the time from your computer when hooked up with the MP driver installed.
Jan 14, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I press scan but nothing happens I scan on cannon Mp 160 and I cant scan with my pc
Make sure the scanner is connected to your laptop/PC before you press 'scan' and is turned on.
Pressing the scan option will start Canan's software MP Navigator for scanning. You can also start MP Navigator on your PC and then start scanning directly from your program or from the printer button.
Dec 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How do you get the Canon Pixma mp500 to scan?
Scanning images,
About Scanning images
You can scan images from the machine to a computer without printing them and save them in popular formats. Scanned data saved on your computer can be processed using image processing software. Furthermore, you can use the OCR (Optical Character Recognition) software to convert scanned paper documents to text data.
* Before scanning
Before scanning images, confirm the following :
- Are the necessary software (MP Drivers and MP Navigator) installed ?
If the software is not installed, install it.
- Does the document to be scanned meet the requirements for an original to be set on the Platen Glass ?
- Is the machine connected to a computer correclty.
Confirm that the connection between the machine and the computer is physically secure.
Scanning Methods.
A) Scanning Using the MP Navigator
MP Navigator enables you to scan in documents loaded on the Platen Glass and view images saved on your computer or on a memory card. Scanned documents can be previewed and easily printed and edited according to your needs.
You can use the supplied application softwares to edit or print the document you have scanned.
Windows : Double-click the [MP Navigator 2.0] icon on your desktop to launch MP Navigator.
Mac : Select [Applications] from the [Go] menu, then double-click the [MP Navigator 2.0] icon to launch MP Navigator.
You can launch the following application software from the MP Navigator.
* Easy-PhotoPrint (Photo Printing)
* ArcSoft PhotoStudio (Photo image editing)
* ScanSoft OmniPage SE ( Converting scanned document to text)
- This application software may not be supplied with teis machine in some country.
Note : If you did a [Custom Install] and only installed the MP Driver and MP Navigator, these application software were not installed and thus cannot be launched. To launch any of the above application softwares from MP Navigator, do a [Custom Install] once again to install them.
For detailed operations of the MP Navigator, refer to the Scan Guide.
B) Scanning Using the Operation Panel of the Machine
You can scan documents to your computer by using the Operation Panel.
Important : Do not insert or remove USB cables when scanning images with the machine connected to a computer, or when the computer is at sleep or standby mode.
*If you are using Windows XP
The program selection screen is displyed the first time you press [Color] or [Black] on the machine.. Specify the [MP Navigator 2.0] as the application software to use, check [Always use this program for this action], then click [OK]. From the next time, MP Navigator is automatically started.
*When using Mac OS X
For the machine to start scanning when [Color] or [Black] is pressed, you need to set MP Navigator as the starting application software in Image Capture under [Applications] of Mac OS X.
1) Press [ON/OFF] to turn on the machine.
2) Load the documents on the Platen Glass.
3) Select the scan option.
a) Press [Scan].
The scan operation selection screen is displayed.
b) Use Up or Down arrows to select the scan operation, then press [OK].
Scan standby screen is displayed.
Save to PC : The document is scanned and saved.
Save as PDF file : The document is scanned and stored as a PDF file.
Attach to E-Mail : The document is scanned, and the image is attached to an e-mai using the e-mail application software.
OPen with application : The document is scanned and displayed on the registered application software.
4) Press [Color] or [Black].
The document is scanned. The settings configured from MP Navigator apply when scanning.
Important : If with some types of original the position and size of the image is not scanned in correctly, please refer to the "Selecting the Behaviour of the Operation Panel with Mp Navigator " in the Scan Guide (on-screen manual). and change the MP Navigator [Document Type] and [Document Size]] to match those of the original being scanned.
Note : The operation to be performed after scanning the document depends on the scan operation setting you have selected in step 3. For details on how to modify the operation settings, refer tp the Scan Guide on-screen menual.
C) Scanning from an Application Software
You can scan an image from TWAIN-or- WIA (Windows XP only) complaint application software and handle the scanned image in the application software. For detailed operations, refer to the Scan Guide (on-screen manual).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
How to use scanner for mp 210 series
You can Scan image from the machine into a computer and save them in,JPEG,TIFF,PDF or BITMAP format.
Scanning Methods:Scanning Using The MP Navigator- Using the MP NAVIGATOR you can Scan process and save documents to your computer.On the MP Navigator 3.0 double click then open it and via:
1 Easy Photo Print(Photo Printing)
2Arcsoft Photo Studio(Photo Image editing )
I shall try to help you
Thanks
Nov 27, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
MP 530 keeps telling me that there is no paper in the trays.
on the paper tray, there is a small plastic sensor that tells the printer that the there is paper on the tray, this may be damaged or stuck one way. please have this checked by consulting the site FAQ on cleaning the Pixma MP
Sep 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannnon mp-530 shows 6a00
Hi
This is same as the wat full
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
PIXMA MP470
Canon 470 printer scanner stopped scanning, Bill
Feb 28, 2008 | Canon PIXMA MP470 All-in-One Printer
Can't use the fax on my Canon MP 530
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough) if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly, So try plugging into the other port on the back, it's just next to the other port hope this helps
Aug 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
50 people viewed this question
old marine
old marine
