Question about Samsung CLP 300 Laser Printer
Samsung Printer CLP300
When I want to print, it sounds as if the printer is trying to load paper, but nothing is happening. Normally there are 4 flashing red lights, however there now is only one red light that stays on consistently. The light which normally indicates that the printer is ready and turns green, now just remains red? Any possible solutions?
  • Anonymous May 05, 2008
    The printer sounds like it is going to print; however, nothing happens. What can I do? It did this last week and then all of a sudden, the printer began working fine again.
Have you run the Dr. Printer utility that comes with the printer? If not, run that and see what it says. You can download it from the CLP-300 support page at samsung.com.
Posted on May 01, 2008
MY SAMSUNG PRINTER CLP300 IS NOT LOADING THE PAPER AT THE TIME TO PRINT HOW CAN I RESOLVE THE PROBLEM?
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 13, 2011 | Samsung CLP 300 Laser Printer
Hello, I was printing a 30 page document on my samsung CLP300 printer and it quit printing after 20 pages. It does not indicate that it has a low ink cart. and I see no signs of a paper stuck anywhere (I...
There are many reasons that causes this printer to stop printing, like empty toner cart, full waste toner cart, paper jam. The only way to know for sure is to use the smart panel program to see what the printer is sensing as a problem and go from there. Hope this helps.
Oct 07, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
My Samsung CLP300 has a paper feed problem. When
Lift up the front of your machine about 4 inches with a book.
The paper will now feed easier.
Richard
Oct 27, 2009 | Samsung CLP 300 Laser Printer
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
CLP300 not picking up thicker paper
this printer only supports up to 120gsm paper,any thing thicker will get jamming errors
Jun 12, 2009 | Samsung CLP 300 Laser Printer
Paper will not feed.
Hi, my name is Alex and I am here to help solve your problem regarding your printer.
Please make sure the paper is preloaded into the printer before selecting print. Also please try turning the printer off and then turn it back on and make sure the paper is loaded when doing this. This is normally a common problem so nothing to be worried about.
One other thing to do, please check inside the printer and make sure no paper is trapped in there, there shouldnt be as you would get the paper jammed window on your screen but when little bits of paper get left inside the printer, when the new paper goes to get fed inside the printer, it doesnt go down properly.
I hope this makes sense to you. Please let me know if you experience any more problems.
Nov 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Samsung printer CLP300
Clean the rubber feeder belt with alcohol. Worked for me, Yesss!!!
Nov 03, 2008 | Samsung CLP-300N Laser Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
408 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
