Microsoft Xbox 360 Console Logo
Posted on Aug 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to setup my xbox to my pc - Microsoft Xbox 360 Console
Anonymous
Level 3:
  • Master 644 Answers
  • Posted on Aug 14, 2010
Anonymous
Master
Level 3:
Answers
644
Questions
Helped
217699
Points
1886
You will need a network cable (cat5) if you have wirless you will have network card at the back of the pc spare, if you dont you will need a network expansion card, plug the cable into the xbox network socket, it looks a bit like a phone socket, and plug the other end into the pc.
The best windows for doing this is windows vista if you are using wirless internet because it allows you to bridge a wireless and cable connection together, windows xp will not allow this.
Goto network connections, goto start and bring up the menu and click settings, then click network connections, you should have two or more connections, 1 wireless and 1 wired, which will be your xbox, you will need to bridge connections, to do the you will have to highlight the both connections by holding CTRL and left clicking on 1 and then the other, now right click on the highlighted connections, a drop down menu should appear, with a option to bridge connections, left click that and a bridge icon should appear in the window showing that the 2 connections are now bridged, you will now be able to use the computers internet access to enter xbox live. You may find that you will have a strict NAT set up on your router, to avoid this you will need to forward some ports, if you get this far post back i will try to run you through this process.
hope this helps and good luck.
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
tip
Configure XBOX with Media Center
Windows Media Center setup on your Xbox 360 Begin by connecting your Xbox 360 to your home network. The Introduction to Home Networking guide on the Xbox website will provide information if you're setting up a network for the first time or if you need some guidance for adding the Xbox 360 to your existing home network.
Once your Xbox 360 is connected to your network, begin the Windows Media Center setup process by pressing the green button on your remote control (if you have one), or use your game controller to select the Media Center option from the Media tab in the Xbox 360 on-screen menu.
You are asked if you want to connect your Xbox 360 to a PC running Windows Media Center in Windows Vista. Select the Media Center option to continue.
Once your Windows Vista-based PC has been detected, your Xbox 360 will display an eight-digit code. Write down this code on a piece of paper, and then go to your Windows Vista-based PC.
Note: When connecting to a Windows Vista-based PC, you do not need to select Continue or download additional software.
Add your Xbox 360 as an Extender to your Windows Vista-based PC Important: During the setup process, the Windows Firewall is automatically configured to enable your Windows Media Center Extender to connect to your Windows Vista-based PC. If you're using extra security software that includes a non-Microsoft firewall, you may need to manually configure your firewall to ensure a successful setup and connection.
With your eight-digit code in hand, begin by selecting Windows Media Center from the Start menu in Windows Vista. From the Windows Media Center menu, select Tasks, and then select Add Extender. This will begin a simple, step-by-step path that will add your Xbox 360 to your Windows Vista-based PC. During this setup process, you will be asked to provide the eight-digit setup key you received from your Xbox 360.
Click through this preview of the setup to familiarize yourself with the process.
The Extender Setup screen provides an introduction of the steps you'll go through to add an Extender to your Windows Vista-based PC. Click Next to start the process.
Enter the eight-digit setup key you received from your Xbox 360 (the one that you wrote down on your piece of paper, right?), and then click Next.
The setup process will need to make changes to your Windows Vista-based PC settings to establish the connection to the Xbox 360. Click Next to continue.
Review the information provided about Away Mode. Make your selection, and then click Next.
The setup process will ask if you would like to share media with the Extender. Select Yes (recommended) to share media folders, and then click Next. If you are using User Account Control, you'll see a User Account Control dialog box that will seek your permission to run the Windows Media Center Extender Configuration. Select Continue to grant permission.
Your PC will now go through the remaining steps to configure itself and establish the connection to your Xbox 360.
That's it! You're done! When you're finished with the PC setup, go back to your Xbox 360, and start enjoying access to all of the digital entertainment stored on your Windows Vista–based PC through your Xbox 360.
Optimize your home network The quality of your entertainment experience, especially video playback, is dependent on having a reliable and high-performance home network. To help ensure the best performance, we recommend that you run the Windows Media Center Extender Network Performance Tuner during the setup process on your PC. The Network Tuner provides very specific feedback on your network, as well as tips to solve any potential problems.
You can click through the preview of the Network Performance Tuner to familiarize yourself with the process.
The Network Performance Tuner runs diagnostics on your home network and provides feedback on potential issues that would make your Windows Media Center experience less than optimal.
When analyzing the network, the Network Tuner provides specific feedback based on all of the components connected to your network.
The Network Tuner provides feedback on the types of media that your network may have trouble handling effectively and suggests corrective actions than can help to solve the problem
The Network Tuner also looks for performance issues related to how your network is set up. In this case, the fact that the Windows Vista-based PC and the Xbox 360 are both connected wirelessly to the router may cause performance issues. You'll only see these warnings screens when the Network Tuner has detected a problem.
Real-time feedback is offered through the Network Tuner, so you can see if the adjustments you make to your network improve the performance.
Regards,
Shrey
on Dec 17, 2009 • Computers & Internet
How do i join and set up xbox live from my laptop to my xbox360 console using a ethernet cable/help
1) Connect your ethernet cable to your computer and xbox
2) On your PC, Go to network connections and right click on your wireless connection
3) Click the advanced tab on top
4) Go to Internet connection sharing and check the box, click OK
5) On your xbox, Go to your network settings
6) Edit settings and set everything to automatic
7) Test Connection
You must have your PC on at all times to connect to Xbox live this way.
If this setup doesnt work.
1) Go to Network connections
2) Select both your wireless connection and your LAN connection
3) Right click and bridge the connections
4) Same setup on Xbox as the previous instructions
5) Test Connection.
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
3helpful
Cannot find the link to xbox pc setup or windows and i am trying to connect my pc to xbox360 but there are no sites that i can go on to do the setup
Here is the link for the how to on connecting your 360 to a pc. Just follow the steps the site gives you. http://www.xbox.com/en-US/PCSETUP
If you found this answer helpful please give me a good rating. Thanks and hope this helps.
Dont no how to setup my xbox live using a t-mobile dongle in my pc???
Okay, here's what you do. Set up the dongle in your PC so internet is running.
Now Connect your Xbox to your PC with an ethernet cable.
Next Go to Start> Control Menu>Network Connections
Choose your internet of choice
Right click it
Choose properties
Click the Advanced tab
Check "Allow other network users to connect through this computer's internet connection"
Now try connecting to Xbox live. If that doesn't work go to Xbox Live Network settings and test connection.
Hope this helps you
2answers
HOW DO I CONNECT MY XBOX 360 TO INTERNET THRU MY DIAL UP MODEM?
Hello Brian
Using Xbox Live on Dial up Modem would be a big pain, still listing the steps for you, hope you have a stable connection to successfully connect
Required Items
- Windows ME, XP, Vista
- PC with dial-up connection working
- Ethernet Cable (RJ45) cable or CROSSOVER CABLE
- Xbox 360
Let's Get Started
1. First connect the Xbox 360 and the PC using the Ethernet cable.
2. Double Click your Dial-up Network connection and wait for it to connect.
3. Choose "Start Menu" and then choose "Settings" then "Control Panel".
4. Select "Network and Internet Connections".
5. Open the "Network Setup Wizard" and then press "Next".
6. On the next screen Ignore the checklist and press "Next" again.
7. Select "This Computer connects directly to the internet." and press "Next".
8. Now Select your dial-up internet connection as your default connection to the Internet and press "Next".
9. Select "Local Area Connection" as your private connection and leave all other areas untouched and click "Next".
10. On the Workgroup screen leave all settings alone and click the "Next" button.
11. On the next screen Turn on "File and Printer Sharing" if you want to share your files, mp3's, divx files with your xbox 360 and click "Next".
12. Now review the settings and click "Next" to apply the changes.
13. You do not need to run the Network Setup Wizard on any other pc's so just click "Next" and continue.
Now that the wizard has completed you may need to reboot your PC and dial your internet connection again.
Xbox 360 Setup
Now we have configured your PC to share its internet connection and files to your Xbox 360 we need to configure the Xbox 360.
(Steps for old Xbox 360 Dashboard, in case you do not have NXE dashboard)
1. Go to the "Xbox 360 Dashboard".
2. Select the "System" Blade.
3. Select the "Network Settings" Option
4. Now choose "Test Xbox LIVE Connection".
Your Xbox 360 will now attempt to contact your home network. It will check to make sure it can assign itself a IP ADDRESS from your PC and then it will also check DNS server information and XBOX LIVE.
let me know if this helps
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Live from pc to xbox
Thats not connecting to xbox live. thats MEDIA CENTER. Streaming music,videos from your PC to your 360.. Evolution!
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
