Question about Refrigerators
Fridge model GR642APA, it is not cooling the fridge but the frezer is working fine, it is also comming up with a "H" on the LCD display. I have cleaned the back of all dust and turned it off for 24 hours it helped a little as it did get cooler yet the "H" is still showing and I am affraid it may not cool again.
  • lenner Aug 23, 2008
    Hi I am having the same problem with my LG refrigerator. Freezer is working well but fridge is not cooling, and is displaying H on the control display. Does anyone know how to solve this problem?
  • pma64172 May 07, 2009
    Fridge is not cooling and a H is displayed turn it off and on and it will work for a short time then the H comes back up
  • 37 Answers
SOURCE: fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Posted on Jan 17, 2008
  • 4 Answers
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
SOURCE: fridge side is not cooling or very low
I got the model 106.56676501 that has the same problem. The freezer side is working good with ice maker but the fridge side does not cold. When I defrosted, it worked for couple of days. Then the problem came back. Would you please give me advise? Can I fix it by myself?
Thank You
Michael
Posted on Aug 01, 2009
Illeagle
  • 525 Answers
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Posted on Aug 13, 2009
  • 670 Answers
SOURCE: Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Posted on Jul 14, 2010
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Apr 16, 2014 | Refrigerators
Kenmore side by side refrigerator model 596.50009100 not cooling.
I would make sure they fan on the bottom that cools the condenser is turning easy way to test is. Put a fan in front of the fridge blowing under it if it starts cooling that is now working right
Nov 12, 2013 | Refrigerators
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Temp in the refrige wont stay cold. frezer is fine. model name is rs2545sh
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Samsung Refrigerators
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Refrigerators
Fridge section not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 05, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
Our frezzer is working fine but the fridge isnt
the return air ducts are frozen, not allowing cool air up to the fridge
unplug unit overnight and let defrost,you can speed up the defrost time by using a blowdryer in the freezer compartment
Jan 16, 2010 | Samsung Refrigerators
Fridge wont cool but frezer is fine
looks like you have a problem with the damper control. try to locate the sensor for the damper control and relocate it, if still not cold, replace it.
May 04, 2009 | Freezers
Frezer working fine but fridge not cooling
Mo, open the freezer door and look for the model tag. There should be a manufacture date on the tag. The product has a 2 year complete warranty, 5year parts and labor on the sealed system and 5-12 years parts only. The factory number is 800-222-7820 and maybe able to tell you when it was installed, They may walk you through a couple of items to tell you what was happening.
Nov 21, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
345 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
