Question about Belling XOU592 / XOU593 Electric Double Oven
Fan assisted oven
I HAVE GOT WATER IN MY OVEN WHEN I CLEANED IT ,NOW WHEN PUT ON KEEPS TRIPPING THE MAINS WHAT CAN I DO..
    Novelist:
    Scholar:
  • 134 Answers
You could try running a hair dryer or even a heater (like an electrical radiator) in the oven.. BUT be careful.. It's possible you might cause overheating of those items Eg melt something or damage an electrical cord etc. You need to drive the moisture away, so the breaker does not trip. But monitor the process closely, as we don't want a fire. Electricians have a special meter called a megger to test the electrical insulation. We are assuming it's just moisture, not an electrical fault causing the breaker to trip. Most problems like this really need a trained tradesperson to faultfind. Take care please, it can be dangerous.
Posted on Apr 30, 2008
Cooking a roast in small oven last nite, all electric went, oven tripped it. Now no top oven working or main oven or fan. What has gone wrong?
When the mains fuse keeps tripping as soon as you switch on the oven, there could be a shortage in the oven, or some of the voltage is leaking to the ground. What it is causing it? I would not know. sorry.
Mar 24, 2015 | Ovens
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
Prestige built in fan oven for no reason keeps tripping the fuse was working good till about a week ago
ISOLATE FROM MAINS SUPPLY BEFORE CARRYING OUT TESTS
Remove oven from unit, remove back visual inspection of wiring, this should take about 30 mins.
Several makes of ovens use heat temp control components, usually mounted on the frame or back of the oven, inspect, if there are signs of heat around the component replace. When oven is switched on is the fan blowing air when the door is open, if not very strong remove fan and clean with WD40, make sure this is dry before fitting again. If fan appears to be working correctly, a heat element could be faulty, inspact when the fan has been removed it should be mounted in front of the fan. If there is black spots, not food build up, it is more grey to black, replace the element, you should be able to get parts from white goods .co.uk. Without more info I am unable to help.
Hope this is helpful
Johnf1
May 17, 2011 | Ovens
Power tripping off at mains when switching oven on
It will probably be the main oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
Jun 03, 2010 | Neff B1641 Single circotherm super...
Oven keeps tripping mains
If it is a electric oven, then the chances are it is the oven element that is causing the problem.
What is probably happening is that as the element gets hotter, the insulation resistance is breaking down, and causing the trip to operate
Hope this helps.
Feb 02, 2010 | Whirlpool Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Belling XOU592 / XOU593 Electric Double Oven Logo
144 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
