HDMI settings wouldn't work
My Sagem Axium HD-L32 tv has suddenly stop recognising the signal from my Virgin V+ Box (cable tv). I am using a Monster HDMI cable and also two scart cables connected to my tv via a Samsung DVD-HR735 Recorder/player. Can you to re-start (kick-start) this conection again?
Many thanks: Jay
  • 5 more comments
  • paisano Apr 30, 2008
    I must clarify my tv is not a projection one but a flat LCD tv. Thanks
    At this moment there is one scart cable connected from my tv to the V+Box(cable tv), another one from the V+ box to the DVD plaayer, another scart cable connected from dvd player to tv and the monster HDMI cable connected from de dvd player to the tv.
    NO that isn't the problem. What's happened is the failure of my tv recognising the HDMI signal through either my V+Box (cable tv) which already has HDMI connection or the DVD recorder?player.
    since we aren't talking about a projector, do I need to be re-directed?
  • paisano May 02, 2008
    Hi IrishDruid! Thanks very much for your advice. I have tried all the cable connections to no avail and will be very much obliged if oyou could suggest to me a qualified technician here in London,UK. Best regards, Jay
    Hi Pauldonp! thankyou so much for your suggestions which I followed to the letter but I'm afraid still no joy there. Could you possible suggest a contact here in London Uk. for a technitian to come and have a look my TV? Thanks again: Jay
  • paisano May 04, 2008
    Special thanks to pauldonp for all his suggestions and the rest of the team who tried to help wit a solution to my problem. I did managed to find a freelance technician, known by a local bussines agent, and who agreed to come and have a look at my connections and after trying switching cables around managed to get the 'handhsake' between my tv and the virgen v+ box. The cable he used was the component one(the one with the white-red-white-red-green and blue)and then went to the settings of virgen v+box for the component and as soon as he press the buttom for these settings on the remote control of the virgen v+ box, he had only witin three seconds to find the connection called YUV on the remote control of my tv and pressed it..and eureka!!! the handshake was established and so was the HDMI settings of my tv to give us a superb HD quality picture!!. There is only one more thing and that is that my dvd player now seems to be at fault since we couldn't get it working, but that's another thing. Thank you again for all your good efforts.
    kind regards:Jay
    President:
  • 2,712 Answers
Most likely a problem with the HDMI cable or the HDMI connector on the TV set.
Try using a different cable, if possible to rule out the HDMI cable fault. Next try the cable on another HDMI enabled TV (if possible). If it works there, it is most likely a problem with the connector plug on the TV itself, for which you may need to engage the services of a qualified technician.
Cheers!
IrishDruid
Posted on May 01, 2008
  • 4,102 Answers
Hi, The best thing to try is remove the leads one at a time then push them all back in again this usually resets in case of any static build up in the leads. Failing this then turn your virgin box off for 15 min i mean unplugged then switch back on it should then boot back up and solve your problem. Try the leads first though to rule them out.
I had this problem last week and turning virgin off at mains seems to solve the problem but off for 15 min or more ok. then get back to me
  • 3 more comments
  • paul proctor May 01, 2008
    Make sure to double check all cables it only takes it to be slightly out for you to lose signal after doing this then switch off virgin box at mains for about 15min. It could even be downtime in your area from virgin it should tell you of any problems on their website.
  • paul proctor May 03, 2008
    Ill have a look for you ok but as i live in birmingham uk then ill have to have a look online for you.
    The only problem is calling someone out will cost a fortune but the problem you have is they do need to come out and actually see whats happening.
    Try having a look through your local phone book im hoping its only soemthing simple and shouldnt cost to much to get repaired. Im thinking maybe the socket for the hdmi might have bad solder this causing you the problem this is easy to fix but depending on how long it takes this is where your going to pay the most, as you know they charge by the hour in uk so can get expensive if it takes to long.
    What ill do is have a look for you then post back any info i can ok but i think the cheapest option would be someone who's self employed as these tend to be alot cheaper than the bigger stores for repairs but its up to you ill get back to you shortly ok
    so you say you have scart in cable going into tv makes sure this is in output on the cable box then into input on telly.
    If this is correct then try pressing the av button on the control 2 or 3 times and see if that gets the picture back for you. if you dont have av button then yours might be source. Now depending om the amount of inputs into the telly this will mean pressing the av button untill you can get the telly on the correct input to reciev the signal.
    Alsl the last time i had this problem it was the box itself so unplugging from mains for an hour solved the problem it just means waiting for your cable box to boot back up again ok.
    Let me know how you get on ok
    Hi just noticed you go it running through the dvd aswell this will then need to be set to the right av channel i think their is only one on dvd player so on dvd remote press av then hopefully it should be working but let me know ok
    Hi also you could try entering the setup on telly control and then go through the menu's and check the hdmi is turned on as they are set to off when sold due to alot of people not having other hd equipment, so this is also worth checking ok get back to me either way ok
    President:
  • 1,944 Answers
What did you do to lose the HMDI output? How is everything exactly hooked up?
Posted on Apr 30, 2008
  • Damen Wong
    Damen Wong Apr 30, 2008
    Thanks for the info. So you can't use your DVD player which is hooked up via HDMI?
2 Suggested Answers
otacon
  • 1944 Answers
SOURCE: I have lost connection to
How did you lose the HDMI output?
Service mode tv lcd sagem axium l32
To know more about this, check the site linked here. It has details about entering, adjusting and exiting service mode to many popular TVs. Pull up older posts.
Nov 27, 2013 | Sagem HD-L26-TP 26 in. HD-Ready LCD TV
No power at all
Check the capacitors in the power supply, check for any bulged tops. Your problem is most likely power supply related.
May 21, 2012 | Televison & Video
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Sagem Axium HD D45F TV Bulb needs replacing - any ideas of a local repair in the Stoke on Trent Area
http://www.ascolti.co.uk/blogs/robsblog/files/sagemaxiumbulbreplacement.html
or
http://robertleather.wordpress.com/2007/09/09/replacing-the-bulb-on-a-sagem-axium-hd45-hs-dlp-television/
Nov 16, 2009 | Televison & Video
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Apr 05, 2009 | LG Televison & Video
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
HD READY
I have the same TV & I've tried connecting it through "component" & the DVI but neither work & a Virgin media tech says only an HD TV will work 'the boxdoesn't recognise component
Steve
May 05, 2008 | LG RZ32LZ50 32 in. LCD Television
Banding on LCD TV
you need a new motherboard
Dec 09, 2007 | Televison & Video
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
Electro Med Services...
