Question about Miele Premier-Plus Built-in Dishwasher
F14 code Miele Dishwasher - Miele Premier-Plus Built-in Dishwasher
  • 177 Answers
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Posted on Aug 18, 2010
  • Miele_Man Nov 20, 2010
    F14 - "level/pressure switch failure." The level switch monitors the dishwasher's water pressure, as it circulates, which is especially critical, during the heating cycle (main wash). Level switch failure can commonly happen from poor circulation, or from the defective level switch, itself. The most common reason for poor circulation is low water fill level. In other words, during the water intake cycle, insufficient water came into the dishwasher. Observe if enough water did come into the dishwasher, Check the water level, by using the filter's handle (located on the floor, of the inside of the dishwasher) as a reference point. At the end of the water fill stage, the water level should be just underneath the filter's handle. If the water level is more than half an inch, below the filter's handle... then that could be a problem. The sympton would be a noisy, sluggish, whooshing sound of water, during circulation - It wouldn't be the same old quiet Miele dishwasher you knew. If you have this problem, then look at the dishwasher's water intake hose. Miele call this their Waterproof System hose (WPS). It's a water hose with an integrated electric valve. First, shut your water valve that connects to this WPS; disconnect the WPS from your valve; look inside the end of the WPS. With a needle nose plier, remove the rubber seal, filter and the water restrictor; clean them of any possible debris; put all the parts back into the WPS, securely; reconnect the hose; open your water valve; and test the dishwasher. If the problem persists, then the WPS will need to be replaced (WPS~$170).
    Other causes for F14, can be weak circulation from foreign item(s) (plastic wrapping, broken glass, etc,...) lodged inside circulation pump impeller, or no circulation, at all (circulation pump stuck). Of couse, the defective level switch, itself, can cause the F14, too. The least common causes for the F14 can be broken wires to and from, level switch and electronic unit, and a defective electronic unit.
    New Friend:
I discovered a simple solution that has stopped the F14 error on my 2010 model Miele dishwasher.
After doing all the recommended cleaning, checks for blockages, rotating impeller etc nothing was working. The pump and drainage all sounded like it was working well but the machine would stop after 4 minutes.
After doing the following process, amazingly, I haven't had the F14 error for over a month.
>Start the senor wash program, you should hear the dishwasher draining any water leftover from the previous load.
>Wait 10-20 seconds after the machine starts filling again.
>Open the door.
>Pour 4 litres of cold water in.
>Close the door & program continues on automatically.
Not sure actually why this worked but I haven't needed to repeat the process again, feel free to comment.
Posted on Oct 07, 2016
SOURCE:
ginko
  • 19396 Answers
SOURCE: miele dishwasher says F14 but
Firts unplug the power cord for 30 minutes and see if this clear the error.
Try cleaning drin hose , filter and non return valve, see if the valve is obstructed.
If you keep getting the error it is better to call a repairman, as you will need to test and replace parts.
Posted on Sep 04, 2008
Basti
  • 1447 Answers
SOURCE: Miele dishwasher G2870 scm.
F14 on your model of dishwasher is indicating a blockage, poor water pressure or could be a fault with the pump pressure level switch or circulation pump.
Filter and non return valve is cleaned of any blockages and if the fault persists have it service..
hope this help.
Posted on Apr 23, 2008
Krazytech
  • 725 Answers
SOURCE: i have a miele g2220
the clogged circulation pump (error code F14)
Posted on Jun 16, 2008
  • 70 Answers
SOURCE: F14 problem with miele dishwasher model G2270SCVI
Hi F14 is when the pump pressure switch does not operate. This can be caused by several things. Circulation motor blocked or defective. Insufficient quantity of water in appliance.Most commonly it is debris in circulation pump.This will require motor to be removed and cleaned.appliance will have to be un-installed
Posted on Jun 19, 2010
  • 37 Answers
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Posted on Apr 20, 2010
F14 fault Flashing. 4 Month old dishwasher. What do I do?
Well first of all, before anyone can help you, you should post the make and model of your dishwasher.
Jun 03, 2017 | Dishwashers
Miele g1220 dishwasher displaying F14
In my case, F14 appeared when the waste pump was not be able to exctract the waste liquids. This happened because lemon kernels (that I use to remove bad smells) has clog the non return valve and the circulation pump passage way. I followed the directions from manual to clean the valve. I found about 30 lemon kernels on the bottom of the dishwasher. After the kernels removal and valve cleaning and refitting, my dishwasher operated as usual.
Mar 11, 2012 | Dishwashers
F14 fault on Miele dishwasher
Hi
F14 means a fault on the heater pressure switch or the water intake.
It could be that either the switch is faulty or circulation pump is blocked, you can check if the pump filter is blocked
Dec 18, 2010 | Miele Dishwashers
What does it mean when F 14 is displayed in the window?
If you have the low water fill problem, then look at the dishwasher's water intake hose. Miele call this their Waterproof System hose (WPS). It's a water hose with an integrated electric valve. First, shut your water valve that connects to this WPS; disconnect the WPS from your valve; look inside the end of the WPS. With a needle nose plier, remove the rubber seal, filter and the water restrictor; clean them of any possible debris; put all the parts back into the WPS, securely; reconnect the hose; open your water valve; and test the dishwasher. If the problem persists, then the WPS will need to be replaced (WPS~$170).
Oct 18, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 problem with miele dishwasher model G2270SCVI WOULD be grateful for your assistance asap as nothing in manual explains what to do. many thanks
Jun 17, 2010 | Miele Premier-Plus Built-in Dishwasher
What is the error F14 in a Miele dishwasher ?
The error F14 in your dishwasher is due to water intake fault with heater or circulation pump, or something like that. The circulation pump would have been clogged. Try to clear it and your problem will get fixed
Apr 04, 2010 | Miele Premier-Plus Built-in Dishwasher
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Miele Premier-Plus Built-in Dishwasher Logo
29,614 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
