Question about Visonik VizuaLogic 82A-79109-6002-L501 Cadillac Escalade 2003 - 2005 Shale Leather with Logo (2nd Row) Car Video Player
Trouble code p1660
I went to advance auto got a reading for my 97 cadillac deville concourse, the code p1660 came up. what area needs to be repaired and what parts do i need if any?
The service manual said that the DTC P1660 is the Cooling Fan Control Circuits
Posted on Oct 10, 2008
How to repair a front pump seal on a '99 cadillac deville concourse
You did not specify which pump. If it's the water pump, you will probably need to replace it, as it is probably the shaft, not a pump housing seal, that is leaking. If it is the housing seal, you will still need to pull the pump to replace it - there is a special tool for this.
Dec 24, 2016 | 1999 Cadillac DeVille
My 97 Cadillac deville concourse transmission is slipping. My fluid was very low and now its slipping. Did I put too much fluid?
take the oil pan off and inspect for any metal particles then change filter and recommended trans oil as is said on your dipstick.you need 10.4 liters of trans fluid.Also contamination in the valve body could cause this and any sensors in it.If your car has over 200000 KM than get it rebuild.
Oct 24, 2013 | Cadillac Cars & Trucks
HOW TO TURN OFF SERVICE ENGINE SOON LIGHT 1999 CADILLAC DEVILLE ELEGANTE
first you have to found the problem and read the code , go to advance auto part and read the code , its free .
Nov 29, 2011 | 1999 Cadillac DeVille
How do i know if my shocks are shot on my 1998 cadillac deville concourse? the back of the car is in the air,and should It sway after I hit a bump??
Hello bagman.... Drive into any auto repair garage, such as an AAMCO repair shop and ask for a free estimate on this repair. A mechanic will come out to your vehicle and test the shocks for you. Since the back of the car is up in the air, it is likely that the front shocks are bad. Shop around and get firm estimates because the charges for this repair vary a great deal from one shop to the next. Joe
Thanks for choosing Fixya!
Jan 07, 2011 | 1998 Cadillac DeVille
Why does my 2002 cadillac deville check engine light pop on and off occasionally? the car drive fine but the light still pops on and off
Hello: The check engine light is telling you there is a problem. To diagnosis and repair you need to go to Auto Zone, Advance Auto or O'riely auto parts stores and have the code read. Then you will know what is causing the problem. You could also go to a GM dealer. There are about 100 things that can cause
to come on.
Nov 02, 2010 | 2002 Cadillac Deville
My service engine light has been on since I've owned my '99 Cadillac Deville, but now sometimes it blinks for a short while. What's going on?
tHIS MAYBE A MIS FIRE CODE dOES THE LIGHT BLINK ON ACCELERATION GO TO AUTO ZONE O'RIELY ADVANCE AUTO ASK THEM TO READ THE CODES WRITEN THEN DOWN THEN YOU CAN ADD THAT INFO TO HELP DIAGNOSIS THE PROBLEM
Aug 19, 2010 | 1999 Cadillac DeVille
How do put freon in a cadillac deville concourse
the answer is simple. you DO NOT!! Even a \licensed mechanic can not if the situation doesn't warrent it. These situations are controlled by the EPA to reduct ground water contamination and putting OSONE IN THE AIR.
Jun 20, 2010 | 1999 Cadillac DeVille
My 2003 cadillac deville-the service engine soon light came on and stayed
On a lot of cars the light is reset when you get an oil change, air filter etc. It's overdue for a "look see". You can always go to advance auto and borrow the code reader for free. Plug it in under your dash and will read and reset any codes
Jun 14, 2010 | 2003 Cadillac Deville
94 Cadillac Concourse Dash color code chart
dawg i had the same problem and there is no way out of this! Believe me i tried it and fired the dash board twice!! I had everything workin got my bangs on and boom like 3 min later it frys. Best bet...go and get the wiring harness. 100 bucks :( but its the only one for ALL Cadillacs! I didnt want to spend the money for it but its was better than frying the dash again and better than using the piece of **** stock radio :)
Oct 19, 2008 | 1994 Cadillac DeVille
1994 Cadillac DeVille Concourse - Runs rough?
The "check engine" light will "light" when there is a malfunction in the engine management system. The fault code is then stored in the computer. The computer must be scanned to retrieve these stored faults to pinpoint the malfunctioning component. We recommend buying your own scanner and doing it yourself. With a pocket scanner you can check for fault codes to find out why the light came on in the first place. You can clear your cars trouble codes after you replace the malfunctioning sensors.
Jun 26, 2008 | 1994 Cadillac DeVille
Car Audio & Video Logo
934 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
