Question about Panasonic Televison & Video
H, I have a panasonic video recorder NV-HV61EB/EBL. The display is lit but it just will not operate. There is a EL 1 error code. Please Help! Kind Regards Nikki
Yes I have solved it.
Press 7 and ext simultaneously on the video remote and player is unlocked.
Kind regards
Nikki
Posted on Apr 30, 2008
Had the same problem, read this answer and tried it.
7 and ext link didn't work immediately so I tried other combos of either 7 with ext link or reset and 8 with ext link or reset. One of them worked but I'm not sure which one - still, that's not too many for you to try. It took a while to take effect (about 10-12 seconds) then the screen blanked then filled with all LEDs, a few at a time and building from dim to bright till the panel was ablaze then settled to the flashing clock. I accessed the menu, set the clock and now, the vcr works perfectly, no problems at all. Brilliant. Never knew that they could be unlocked. When I think of the number I've chucked........
Posted on Apr 28, 2010
Model NV-HV61EB/EBL. Why has it suddenly stopped recording in wide screen?
On the menu screen go to the "others" menu. Make certain it says on the "OSD" - wide!
As this is an older model with no digital tuner I assume you are recording from another source. So check that is outputting widescreen pictures to the VCR. If you have it connected via a scart lead - replace it with a high quality one. They are terrible for causing faults like that.
Nov 01, 2015 | Panasonic Televison & Video
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Manual for panasonic NV-HV61EB
You may download a copy of the manual here.
Jul 14, 2012 | Video Cameras
The camcorder is failing to record
Hello
Do you mind to be i a little more specific on this particular error. Does the camera display any error code?
Let me know, i will gladly assist.
Kind regards
Andrea
Sep 28, 2010 | Panasonic NV-MD9000EN Mini DV Digital...
I NEED AN INSTRUCTION MANUEL FOR VIDEO RECORDER NV-HV61EB
send me a request to slinteriors@yahoo.com and indicate the model number and type manual Service or user.
Apr 03, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Videocamara en japones: quien puede publicar el manual de instruc
Also refered to as nv-gs50e or nv-gs70e. Go to http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-75489-Camcorders#Anchor_13 it will be the third driver from the BOTTOM. This model has been discontinued so support for later windows editions are not likely. Windows 2000 is the last version you can always run your compatabilty mode with 2000 for optimum preformance.
PAL Mini-DV Cameras/recorder
NV-GS50E
Dec 29, 2008 | Panasonic NV-GS50 Mini DV Digital...
Panasonic Video Recorder has stopped working
looks like some kind of sensor within the mechanical part, its seems like the mechanism doesnt return fully to its original point giving you these kind of malfunctions, I suggest to take it
to an authorized dealer for a complete check up & tune up
Apr 15, 2008 | Panasonic NV-HS1000 S-VHS VCR
Televison & Video Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
