Question about Brother MFC-5440CN All-In-One InkJet Printer
Remove mfc 5440cn print head
Hi all I need to remove the printhead from my 5440 so I can give it a good soak. does anyone have any instructions to do this. I cannot find anything anywhere. thanks
  • nash1951 Nov 23, 2008
    I can't print in black, but can print in color. replaced the black cartridge, cleaned the head multiple times, no success. Please let me know how can resolve this issue. Thanks.
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Posted on Dec 20, 2008
  • 74 Answers
I would not recommended this without a service manual. i would try to google "service manual for Brother MFC-5440CN" such as here
http://www.smpcshop.com/MFC5440CN-MFC5840CN-p-3972.html
Best of luck
Posted on Oct 19, 2008
Brother mfc 5440 black ink is not working.
Usually this is a printhead problem and the printhead will have to be replaced. You can call Brother at 1-877-BROTHER to see if they will cover the repair under a special warranty and to find the closest repair center.
Jun 01, 2011 | Brother MFC-5440CN All-In-One InkJet...
I just purchased a brother mfc-6490cw and it will not print in black. all other colors look good on the test print. I have installed a new black cartridge and cleaned the print head several times. any...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 08, 2011 | Brother MFC 6490CW InkJet Printer
Have ink, but its not printing. the paper is doing the right thing ,but not putting ink on paper
Please make sure that the print head is not clogged. The ink can flow out easily from the print head. How do you know if there is no dry ink clogging the print head? Remove the cartridge and run the print head in a soft smooth paper, see if the inks was left in the paper proportionally. If no ink marks then its clogged.
flushing the print head of the cartridge directly from the tap water will help ....Open your printer cover, remove the cartridge..place the printhead directly on a tap water running slowly. This will help flush the dried ink that clogged in the printhead. Turn the print head over, bottom side up until you see the ink flowed out from the printhead, do this until you see the a smooth flow of ink..(better result if the water is warm).. tap water contains residual minerals that can clog also the printhead..so it is advisable to final flush the printhead with a distilled water (it has no impurities) and dry it with cloth..
The last thing to do and it will take you sometime is to soak the printhead portion of your cartridge in a mixture of ammonia and hot distilled water, (please make sure that the contact point of the cartridge to the printer is not soak).. Place the printhead on the hot water and leave it there for about 4 to 5 hours..move it on different location from time to time..After soaking, rinse it with distilled water and dry it with cloth...
After doing the instructions, return back the cartridge to the printer and do the printhead alignment..
Try printing a test page and see the outcome...
If you find this information very helpful, would you be kind to rate this solution. Thanks
Aug 18, 2010 | Brother MFC 420CN All-In-One InkJet...
I need a reinstall disk for the 5440
Drivers, manuals, etc. for the MFC-5440 can be found here.
Good Luck!
Jan 26, 2010 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 5440CN Low Ink problem
Maybe you can try reinstalling the driver or if the cartridge was bought from 3rd party, you might want to buy one directly from the manufacturer.
Good Luck.
Feb 02, 2009 | Brother MFC-5440 Printer
Brother MFC5440CN - Yellow cartridge does not print despite being
Print head will have to be replaced. Whenever one or more colors won't print and you've gone through the cleaning process, the printhead is bad!
Jan 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440 Print Head
To remove it you pretty much have to take apart the printer, tip up the lid and try and get the scanner cover verticle and then slide to the left it should detach and then undo all the screws you see on the top were the pinter head is, and i would recommend Alcohol Swabs (IsoPropyl Alcohol), Then just reverse the dissassimbay directions
Thanks Mitch
P.S. Don't forget to rate me
P.S.S. If you follow my directions you do so at your own risk, I am not liable for any damages that occur
Aug 21, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 5100C making white line in printing
The printhead is probably clogged. You may be able to clean it, by removing the mechanism and soaking the actaul printhead in a solution of white vinegard or you may have to replace the printhead. A web search may result in instructions on how to remove the head. Prinheads appear to still be available via Ebay and others. They run about $60-70 and if you have a bit of tech abilities, replacment should be relatively easy to do yourself. Not sure about finding a repair center that will do it for you or what the associated cost would be..
Feb 12, 2008 | Brother MFC 5100c InkJet Printer
Brother MFC-5540cn Print Head replacement
Its quite siple to do if you are able to use a srewdriver... 1#: Go get a 2.hand dcp 110c or 115c at eBay with a good printhead (and a broken scanner glass???). It should print without probs! opening mfc 5440 is nearly the same as a mfc 215c, since all brother printers are of the same built :) follow pictures here http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c For your mfc you have to unfasten some more screws which can be seen very well. After that you can take up the cover. Now you should realize that it looks the same inside as on photos given in the link. Read the rest of "how to change the printhead" here: http://www.fixya.com/support/t209702-get_color_print_black_works_fine there is just one more difference to your mfc! You have to take out the sensor in the ink cart assy of your mfc 5440cn which is clipped at the side and reinsert it into the cart assy of the "new" one! This sensor is placed at the BK cart and signals the mfc that there is a HBK cart. Thats it. This job could be done for a novice within less than an hour. If there are questions afterwards or during surgery post it here!
Oct 05, 2007 | Brother MFC-5440CN All-In-One InkJet...
Printhead
TRUST ME , IF YOU HAVE NEVER PUT A PRINT HEAD IN YOU ARE IN DEEP S--T. MAYBE THE SERVICE CENTER OR WHO EVER SOLD THE PRINT HEAD TO YOU WILL DOWN LOAD THE INSTRUCTION SHEET. MAYBEEEEEEEEEEEEEEEEEEEEEEE THEY WILL DO IT I DO NOT KNOW AS THIS PRIORITY INFO, GOOD LUCK BROTHER SR TECH
Aug 29, 2006 | Brother MFC 7300C InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
1,954 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
