Question about Hitachi 51SWX20B 51" Rear Projection Television
Red out of alignment then all went black. Hitachi 51SWX20B
Hello Experts,
My mothers TV stopped working today. Just before it quit showing a picture it looked like the red had shifted from the greens and blues. I went to the magic focus setting on the remote and it started to go through the magic focus utility and then it just stopped midway through the first color (Red) It then went back to the picture mode and it was the same... Red was shifted. The picture went black shortly thereafter. There is also no sound now. The red power light does come on when pressed. But goes off after a few minutes. There is also a faint clicking sound. from the back of the set. I am a PC technician but do not know much about TV sets. I need to mention I had a Comcast guy here the other day to clear up a tiling problem on the HD and it all went well. I think... The screen had like tiles randomly appearing and the sound was on and off on and off. I have been having this problem everytime it rains or a snowflake flies, and sometimes when a cloud passes over the house. It usually clears up by itself. This time it lasted a few days so I called. The TV was working great. The guy did check voltages and worked on the pole and changed a connector at the house. There is an amplifier and 2 splitters I think in the basement. We also have 3 other TV's but they are just regular cable... Not HiDef. The one that went out has its own Comcast HiDef Box. Is there a chance it could be Comcast? Maybe just a Strange coincidence? Any help would sure be appreciated.
Dan
  • 1 more comment
  • nanodano May 08, 2008
    I changed the 2 convergence chips and still the set will not come on. The chips were STK 110 AND STK 150 - I replaced them with the STK 180 chips and It was a perfect swap and solder job. When I plug the set in the board comes alive but, there is 1 green diode that clicks and flashes 5 times then goes out along with all the other lights. There are 3 boards. The bad light (diode?) is near the top of the center board. It is the second green light from the top . I should add that It also looks like a tiny green (resistor?) has gone bad by the IC's... it has a black discoloration in the middle of it. All the other ones look bright green. Also the flyback transformer is a brownish color around the base of it . Is this just normal for the flyback because of heat being generated by the transformer or is this possibly the part that needed changed all along? I was going to use the premium service but it is not working. Can someone post and help me get through this. I am a PC repair tech nor really a TV repairman. If you have PC problems I can help. ASK ME! From one tech to another I have TV problems can you please help me? MOM is getting stressed.
    Thank you everyone.
    Dan
    Here is the picture of the diode that flashes and clicks. Can someone tell me what the 5 flashes and clicks mean?
    Hitachi 51swx20b
    The green diode that is clicking and flashing is circled in yellow and also take a look at the flyback. I took the set outside and lightly airchucked the bulk of dust on the boards. Those are the 2 new STK 180's. The discolored resistor is also circled in yellow.
  • Hitachi Master
  • 8,617 Answers
The resistor near the Convergence IC is most likely the problem go to the link that I am posting and enter the resitor location such as RZ129 or whatever it is and they will tell you the rating of the resistor that youre needing.Include your model number
http://servicemanuals.vstore.ca/
Posted on May 17, 2008
I have a Hitachi 51SWX20B. I experienced a power loss and according to the local power company a surge due to a transformer being hit. After power was restored, the TV turns on (red indicator light on...
Unplug,replug the tv back about an hour later.Let the tv to get out of it protection mode,might work again.Not,come back give the new problems,help u some more.
Jun 15, 2010 | Hitachi 51SWX20B 51" Rear Projection...
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Have an Hitachi 51swx20b. The colors are not aligned and magic focus will not work. Vertical and sharpness is grayed out...
Ur convergence it dead.U know how to solders?Buy a convergence kit to replaced parts.Websites Tv repair World.com Tvrepairkits.com.
Dec 16, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Was watching tv there was a flash of light picture went out and no sound either red led power light comes on but thats it no pic no sound
Replace Both of your STK ICs nd 6 resisitors they are big black ICs will have part # on them STK392-110s .
RK42-RK 46-RK50-RK54-RK58-RK62
3.3) -( 1.8) -(2.7 ) (1.5) (3.9)- ( 2.2ohms)
Sep 25, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51SWX20B, no picture, burning smell, still has sound.
electric when out and came back on cable box rebooted, tv red indicator light come on but no picture tried uplugging tv and left off for a while plugged back in no picture but tv comes on.
Aug 22, 2008 | Televison & Video
Hitachi 53UDX10B no red color
The red cable from the cable box was loose.
Jul 20, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Old Projection telvision on the fritz
you need to change the CONVERGENCE ICs , if you cant do it then it needs to be serviced by a HITACHI authorize service shop , hope this helps AJ
May 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
HELP! Can you help me Slinte?
Can you post the board location number of thr resistor that is circled in yellow such as R8006 and I will post the rating of that resistor as thats what the problem is usually one or two of the resistors will burn when the ICs go out.
May 10, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
655 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
