Question about Nikon Cameras
The viewer box says remove lens cover . cover is off
MY SOLUTION WAS TO USE AN OTHER CAMERA THAT WORKS A CANNON WAS USED WITH NO PROBLEMS THANK-YOU
Posted on May 09, 2008
Remove moisture inside Olympus digital camera
Place it in a sealed container covered in rice for a few days. The rice will absorb the moisture. Works on cell phone dropped on water too.
Sep 02, 2014 | Olympus TOUGH TG-310 Digital Camera
How do you remove the tail light lens cover for a 1987 Nissan Pickup truck
You can't remove the lens cover. The tail lights are molded as one piece. If you want to change the bulbs, there should be an access panel inside the truck box right behind the tail lights that gives you access to the bulbs. There are also screws to remove the entire tail light assembly if it needs replacing.
Sep 05, 2011 | 1987 Nissan Pickup
Sorry to sound dumb but where do I find the lasar reader in order to clean it?? Thanks for your help
For Original (the big Fat one)
    • 1 Turn the PlayStation 2 over to remove the screw covers. Use the flat head screwdriver to remove the plugs that cover the screws. This reveals several Philips screws. Do not remove them yet. They must be unscrewed in a certain order so that the PS2 opens up properly.
    • 2 Remove the small screws near the control ports, powerboard and DVD drive using a Phillips screwdriver.
    • 3 Remove the long screws from the upper right section. This enables you to remove the cover.
    • 4 Flip the PlayStation 2 over to open it up. Before opening it, ensure the PS2 has had adequate cooldown time. Wait at least one hour after playing the game station before continuing. You do not want to burn yourself on the hot elements within.
    • 5 Open the PS2 carefully so as not to damage the ribbon inside the console. Lift up the case gently and slide the cover off. Notice the big black box that contains the laser lens and DVD drive unit you need to clean.
    • 6 Locate four black, small screws holding the black box down. Remove the screws using a Philips screwdriver.
    • 7 Lift up gently on the cover of the DVD drive. This fully exposes the laser lens.
    • 8 Dip one cotton swab in rubbing alcohol. Gently rub around the edge of the lens with the swab. Look for any greasy residue that may be there and remove it. Remove any fuzz. Use gentle pressure so you do not damage the PlayStation's lens.
    • 9 Take a dry cotton swab and dry off any liquid left behind. Ensure there are no cotton fibers left behind on the lens.
    • 10 Reassemble the PlayStation 2. Work backwards from the way in which you disassembled it.
Tips & Warnings
  • Opening up your PS2 voids your warranty. Do so at your own risk. If you are not comfortable working on your PlayStation 2, have it cleaned at an electronics store's service center.
And for the Slim
    • 1 Open the lid to the PS2's disc tray.
    • 2 Spray the lens with a few quick, short bursts of compressed air, keeping the nozzle several inches away from the lens.
    • 3 Apply a small amount of lens cleaner or isopropyl alcohol to one end of a cotton swab.
    • 4 Rub the damp end of the cotton swab against the lens in a gentle, circular motion, for roughly 10 seconds. Be incredibly careful and use a miniscule amount of pressure so you don't accidentally scratch the lens.
    • 5 Dry the lens using the opposite end of the cotton swab.
Jun 04, 2011 | Video Game Consoles & Games
HOW TO OPEN THE FUSE BOX UNDERNEATH THE PASSENGERS SIDE
HI viewer! . You need to remove the cover beneath the right kickpanel. There are two pop-up retainers to remove. When removed, lower the cover and pull outwards. As for the fuses , you need to work beneath and probe on the fuses accordingly. There are labels you can find there, too. okay? : )
Dec 30, 2010 | 2008 GMC Acadia
I found the fuse box in our 2008 Acadia under the passengers side of dash, how do I drop it down to access fuses?
HI viewer! So you found the location of the I/P fuseblock. You need to remove the cover beneath the right kickpanel. There are two pop-up retainers to remove. It is this cover that you can drop down and out. As for the fuses , you need to work beneath and probe on the fuses accordingly. I hope you'll be okay, and goodluck! :)
Nov 06, 2010 | 2008 GMC Acadia
My ps2 slim is not reading any discs why ?
Hi. Try to clean the lens by using a qtip and alcohol. Here's the procedure on how to clean the lens.
  • Sep 04, 2010 | Sony PlayStation 2 Slimline Console
    When I turn on my ps2 it spins the disc but does not read it. It goes straight to the browser system configuration screen like there's no disc in it. It worked earlier but froze up now this is what its...
    Hi. try to clean the Lens of the Unit. Please see procedure below:
    Lense cover won't open
    Dirt or grain of sand in the small gear box that drives closing and opening of lens cover. Remove front assy. and if you are brave dismantle gear box to clean out. Otherwise just blow without dismanling the gear box.
    Aug 28, 2007 | Canon DC40 DVD Camcorder
    Canon A520 Lens Jam
    if your lens stucked up, maybe the motor got the problem. br4ing your camera to the nearest service center in your place
    Jul 03, 2007 | Canon PowerShot A520 Digital Camera
    Cameras Logo
    13 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
