Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
  • 2 more comments
  • Anonymous May 08, 2008
    i can't install to window xp
  • doneitel May 09, 2008
    I use the drive to backup our server. After using it for several
    months, my mac says that it can't read the disk. I don't want to
    lose all of my past backups.
  • Anonymous May 21, 2008
    the laptop ask me for the driver
  • ECasebeer May 21, 2008
    generic volume in use the error message says. I have eliminated shortcuts, turned off computer. what else?
Posted on May 30, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ... > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
SimpleTech 250 gig external drive not recognized on MacBook
It could be formatted in a different manner. See if it is detected by your mac. Go to Applications/Utilities/Disk Utility and see if your hard drive is shown there. If it is, then the formatting of your hard drive is not compatible and you will need to reformat to be able to use it on a mac.
Nov 02, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Where can i get the installation softare for simpletech 250???
you can check on the official site from here ;you need to plug in USB to be recognized by you PC or laptop after that you can acces your hard drive when is instaled make a reboot to be sure that is instaled properly.
Dec 10, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Error code 16
Code 16 is a hardware or firmware failure you need to Surf a little and reveiw the home page. Hold on ill get the address to take you too the solution
This may resolve the problem and grant you access to your HD
Oct 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My SimpleTech 250 gb external hard drive has changed from being
The reason for drive letters changing is often as simple as having two plugged in at the same time. Changing them again is simple but should be done while all drives are plugged in simultaniously.
So, plug in both usb drives, then right-click on My Computer and select Manage, when the management console opens select disk management. Strating with the other USB drive, select it on the right hand side and then right-click it and select "Change drive letters and paths". Select change from the next window and select a high letter X/Y/Z from the drop down box. Then click ok.
Repeat the last few steps with the external harddrive and select E, when you're done you should have to restart to allow the changes to take place but then it will be set in. You will have to repeat this process if you change which USB port you use for the hub or if you add other additional external drives.
Hope this helps FixYa,
Jun 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My computer wont read my Simpletech 500gb hardrive
SimpleTech has problems with their controller board. The HDD inside probably still works fine. You might want to get an external chassis and take the hard drive from the SimpleTech and put it into the external chassis. You will need a sata one.
May 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech usb drive model 96300-40001-001 Mac OS9 compatibility
If its 9.2 it may be because your mac is usb 1 and your external HDD is usb 2. It will recognize it but sometimes it takes longer to see the drive.
Feb 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Opening simpletech download onto Acer with Vista
hard drive with high capacity are always fagile and they get crashed easily.why not try a new hard drive.
Jan 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
142 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
