Leakage of gas every season
My AC has not been working properly from the beginning. Every season the gas leaks and cooling is also very low. I am not happy with the service provided by the company (carrier). what should I do?
  • 236 Answers
The technician should locate the leak and fix. The problem cannot be solve if the location of leak not find.
Posted on Apr 30, 2008
Ac not working properly on my 98 Pontiac Grand Prix...
Check AC pipes for leakage/pressure/gas agent.
Apr 24, 2015 | 1998 Pontiac Grand Prix
Why did my Hairer 8000 BTU portable A/C quit cooling on cool mode? It was working very well. This afternoon, I went into the bedroom, where the A/C is located, and room was not cool. When I switched t
Do you hear compresser start up noise. If so then please check it with a clamp meter and Amperage the Unit is drwing. If it is less than 8-9 Amps than there is some leakage in the AC and all the collent has leaked. So you got to get it serviced.
Sep 25, 2014 | Haier Heating & Cooling
My car AC stopped cooling. it started working again after I refilled the gas but stopped working less than 24 hours after. So I suspect there is a leakage somewhere on the Evaporator
It could be a leakage, but maybe you are low on refrigerant (the liquid that goes into AC's to make them cool).
In both way you should see a mechanic.
Sep 10, 2013 | 2008 Toyota Camry
Subaru tribeca 2007 A/C problem
ac leaks are found by vacuum down the system and seeing how long the vacuum holds for
,mechanics are seldom qualified to check a system and if they rely on sensors to do the fault finding will not find slow leaks such as compressor seal leaks or connections leaks
leak detection dye and appropriate colored lens in glasses and using an ultra violet light will reveal a leak better
to test for gas , use a proper gas manifold gauge using 2 gauges --one measures the low pressure side to check for blockages and the other to measure low gas pressures or blockages causing high pressures
Jun 24, 2017 | Heating & Cooling
1987 cxr si ac not cooling
The most common cause of your lack of cooling is no or low refrigerant charge in the system, in most cases this is due to the front shaft seal of the AC compressor on the engine leaking, if it is leaking you will see oil deposited around the front of the compressor behind the drive pulley magnetic clutch. Of course there are other places that leak and other problems that cause lack of cooling, but check for a lost charge due to leakage first.
Feb 10, 2012 | Honda Cars & Trucks
My beverage air refrigator ri18 compressor turns on sounds like it works but doesnt get cold
1) Check the compressor working or not.. Air cooling type condenser fan may be not working properly.
2) Compressor working but not properly. Last side of condenser (Filter) Light Heat or not.
3) Inside Cooling area do not get cooling. may be gas leakage problem.
4) My opinion check Gas pressure Low and high side.
Mar 26, 2011 | Freezers
E4 Error in Hunday Split Ac
Your technicians are not properly locating the source of leak and repairing it before adding more refrigerant. Have them use a leak detector(sniffer) or colored dye that will reveal the leak. Then repair and fill to specs.
A refill of a slow leak will work until refrigerant it leaks out again.
Sep 02, 2017 | Heating & Cooling
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
I had a new radiator installed in 1995 geo prizm & now only get barely cool air from air conditioner, which immediately prior to installation was ice cold. Mechanic is saying there's no connection...
ask him if he remove the condenser prior to install the new radiator?
have your system check for refrigerant level, if it is low, then it could have leaked out, or it was removed and not properly charged after installing the radiator, or they could have touched on the lines of the ac that made it leak some gas.
a lot of things could have happened.
tnx 4 using fixya,
drcool
Sep 03, 2008 | Geo Prizm Cars & Trucks
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
