Question about Cell Phones
When I click onto the bluetotth icon on my phone it flashes up 'you must set bluetooth address'
YOU CAN TYPE ANY ADRESS, AND THEN TYPE SAME ADRESS ON OTHER MOBILE WHICH YOU WANT TO CONNECT
Posted on Apr 30, 2008
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
I using samsung corby gt-3653 unable to delete devices from bluetotth please hep?
Hello Dear ,,,, I think U tell about Samsung Corby GT-3653 ,, If am I right then its very simple to delete a pair devices from U'r Bluetooth service list ,,, at first u have to activate the Bluetooth system and click on desire device which U want to delete, then a popup will open then scroll it down, U have a option names Delete > then simply delete it or Multiple,,, OK !!! simple, isn't It ?
Mar 25, 2011 | Samsung Cell Phones
I need to connect a new phone to my lexus 460ls bluetooth system
Go into the information /Nav Screen and you will find an icon for phone, then settings. Click on the icon and it it will give you a connect new phone option, click on that icon and it will release a 4 digit entry code and be findable by your phone.
Next go to your phones tools or connections settings and look for Bluetooth, enbale Bluetooth, Search Bluetooth Devices/handsfree Your phone will search out the car, once found it will request the 4 digit pin code to be input and ask you to confirm "handfsree" Once confirmed the car will read out connecting...then bluetooth connection successful and the dial pad will appear on the NAV screen
If you have more than one phone connected to the car the driver will need to select the connect phone button in order to chose the phone he wishes to enable
Jan 17, 2010 | Lexus LS 460 Cars & Trucks
Cant find a manual jabra bt4051 bluetooth
abra burst onto the audio microtechnology scene in the early 1980s, gaining initial attention for its Macintosh EarPHONE telephony products. Jabra's cell phonemag-glass_10x10.gif Bluetooth headsets have also garnered wide acclaim for their sleek aesthetics and compact form. Jabra Bluetooth headsets can be connected or "paired" with virtually any cell phone by using a few simple steps.
  1. Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
  2. Step 2 Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
  3. Step 3 Release the power button.
  4. Step 4 Navigate through your cell phone "Settings" menu and ensure your "Bluetoothmag-glass_10x10.gif" or "Hands-free" section is set to the "On" or "Active" mode.
  5. Step 5 Elect to "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
  6. Step 6 Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
  7. Step 7 Select a "Connect" or "Pair" option once the Jabra headset name is discovered and displays on your cell phone.
  8. Step 8 Enter the default passcode by entering "0000" on your cell phone keypad.
  9. Step 9 Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Nov 12, 2009 | Cell Phones
Want to bluetooth ringtones with my Iphone to other phones
Unfortunately, the iPhone doesn't support that. Neither does it support sending pictures byu bluetotth.
Oct 16, 2009 | Apple iPhone Smartphone
Lg vu
User must be logged in as Administrator or have administrator privileges to modify system files
Setting up the handset
1. On the handset, touch the Menu icon located in the lower left corner of the main screen.
2. Touch the Settings icon located on the bottom of the menu tabs.
3. Touch the Bluetooth icon.
4. Touch Turn On.
5. Touch Settings.
6. Touch My Device Visibility.
7. Touch to select On.
8. Touch Set.
Setting up the connection
1. On the PC, double click the My Bluetooth Places icon on the desktop.
2. Click View devices in range.
3. If the handset does not appear, click Search for devices in range.
4. Right click the icon representing the handset and click Pair Device.
5. Type a numerical pin code (example: 1234) in the Bluetooth PIN Code field and then click OK.
6. On the handset, an Accept? prompt will appear, touch Yes.
7. Type the same Bluetooth passcode (Bluetooth PIN Code) entered on the PC and touch OK.
8. On the PC, return to My Bluetooth Places.
9. Right click the icon representing the handset and click Discover Available Services.
10. Double click the Dial-up networking icon.
11. When the connection window opens, click Cancel.
12. Click Start, Settings, Control Panel and double click Phone and Modem Options.
13. Click the Modems tab.
14. Click to select Bluetooth Modem and click Properties.
15. Click the Advanced tab.
16. Type at+cgdcont=1,"IP","isp.cingular" in the Extra initialization commands field.
17. Click OK.
Making the connection
3. Right click the icon representing the handset and click Discover Available Services.
4. Double click the Dial-up networking icon.
5. Type ISP@CINGULARGPRS.COM in the User name field.
6. Type CINGULAR1 in the Password field.
7. In the Dial field, type *99#.
8. Click Dial.
You will now be connected to the AT&T data service
NOTE: I had to change every instance of "isp" to "wap" for this to work (including the Advanced Settings Tab), but y'all might not have to. Hope this helps.
Apr 22, 2009 | LG Vu CU920 Cellular Phone
My lg incite bluetooth does not detect the motorola S9 bluetooth
this took me nearly an hour to figure out, but here goes:
go to "settings icon" - tap "bluetooth" - turn it on - go to "accessibility" tab - make sure your phone has a "name" - then make sure "allow other devices to connect", "all devices" and "other devices can discover me" are selected - then go back to the "general" tab - tap on the "bluetooth manager" link - go to "active connections tab" - click on "menu" at the bottom right corner - click on "paired devices" when the menu comes up - click on "add".
Now quickly put your bluetooth headset into pairing mode and as soon as the device and passkey asking screen comes up, tap on the little windows "find" (or "search") icon next to the "device" field. once your phone detects your headset, it will take you back the device and passkey screen, where the name of your headset will now appear in the device field. all you have to do is input your device passkey.
Now go back to "bluetooth manager" screen, where in your "my shortcuts" tab, your "hands-free connection" icon should be present. if it's not, then click on "new" in the bottom left corner and select the "hands-free/headset setup". On the screen that comes up, select "next" which will take you to the next screen. Here your headset device icon will be present with a small red checkmark beside it. Tap this and your phone will establish a connection with your headset. It will then take you back to "bluetooth manager" - "my shortcuts" screen where your "hands-free connection" icon will now be green with two small arrows beside it pointing towards each other. If you click on the active connections tab, you'll see your headset device icon there. Also, a pair of headphones will pop up on your windows toolbar at the very top.
After this setup, to ensure your phone's security, go back to the "settings" - "bluetooth" - "accessibility" tab. Select "paired devices only" under the Accessibility heading, and deselect "other devices can discover me".
Hope this helps everyone...so far this is the only non-user friendly feature of the phone that I've come across, rest is pretty good and highly customizable.
Mar 20, 2009 | LG Incite Cell Phone
Bluetooth can't detect new devices!
You might want to try to Reset Settings and see if that works first
1. Go to Menu
2. Select the Settings tab
3. Select Phone Settings icon
4.Select Reset Settings.
Once you do this, turn your phone off and back on, and try this next if u have Bluetoot of turn it back on.
1. Go to the Bluetooth icon
2. And select Settings
3. Select My Address
Make sure your My Bluetooth shows an address like
00:1k:54:nj:54:m5 (not a real address but should be same form)
If your bluetooth addres has been removed or corrupted contact me back.
Dec 07, 2008 | LG KU990 Viewty
Connecting bluetooth to an apple
Here is the process you need to do in order to connect your phone to a mac through bluetooth...
1. Go to system preferences 2. Click on bluetooth 3. Click on devices 4. Click Set up new device 5. Follow the set up steps and you're done
Good Luck
Oct 16, 2008 | Sony Ericsson K750i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
