Question about Mag Innovision LT776s 17" LCD Monitor
Dell 17 in. LCD Widscreen with Speakers
Need help with this Monitor/TV. Was working fine and then just went out. Power light comes on and when switching between monitor and tv I can hear the tv come on but no picture or sound. Any suggestions? Is it worth repairing cost wise?
  • 111 Answers
This problem may be caused by bad inverter or Cold cathode bulb. This can normally be repaired by a qualified shop or technician.
Hope this helps.
If it does, pleae vote.Thanks!
Posted on Apr 30, 2008
My monitor appears to have no power. No front lights though the power cable is good.
Hello Dave,
Check the power light, if it is faintly blinking then this link should help you get it going. That model is well known to have a problem on the control board that causes the monitor to not power up right.
http://www.instructables.com/id/FREE-17%22-LCD-Monitor---How-to-do-it%3f/
Nov 06, 2012 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
No power to Dell E173FPc monitor; power light doesn't come on
It sounds like you are not getting any power. I would try another power cord to see if it makes a difference.
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
No sound coming from my Dell 173FP monitor
This monitor does not have built in speakers you will need to buy some... The AS 500 soundbar fits on to it but is now not available. See if you can find it second hand.. Or buy USB speakers that fit into the back of your PC as the mointor does not have any ports.
Nov 20, 2008 | Dell E173FP 17" LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
19 in Dell flat panel monitor
also need to see video how to remove back of monitor case
May 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
37 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
