Question about Epson Stylus C42UX InkJet Printer
Cabling problem?? hello there. I have an epson c42ux printer. while trying to open my printer case so as to remove and wash the pads.. ive got a cable(thin plastic) connected to the base of the catridges off. so i put it back again and now I have both the red and green light on.(no flashing). when i run the utility it says insert original epson catridges and dont recognize anymore the catridges i was using. is the cable causing the problem or should i try new catridges..???? anyone can help plz...
  • wonderboy16 Apr 30, 2008
    i placed the cable the right way up and it went in correctly.. hmm a ressetter? i have got the ssc utility but it says device not found.. i have selected c4* series and printer is on and recognised by computer... :(
  • wonderboy16 May 02, 2008
    well i dint removed the cables... while replacing the casing back... i noticed the little cable detatched... i think i did that in carelessness...
Buy a new printer !!
Posted on Jul 08, 2008
    Scholar:
  • 154 Answers
Perhaps that the cable isn't put in the way it should , but it could also well be that you need a chip resetter for epson cartridges to let it recognize the cartridges correctly
Posted on Apr 30, 2008
  • dirk boon
    dirk boon Apr 30, 2008
    i myself as a systembuilder have never tried to clean printerpads by removing the cable, are you sure that the cable is good , that there is no bend or knick in on of the signal ways?
Epson stylus c42ux how do I put in new ink? I can't get to the print cartridges
Power up the printer and open the lid. The print head should come to the center. When you close the lid, it will go back to it's park position. Don't pull it over with the power off.
Jun 01, 2011 | Epson Stylus C42UX InkJet Printer
Replaced waste ink pad.... still can't reset the printer to continue printing
You need a program called SSC which will reset the counter. If this fails you need to find your nearest epson express centre where they will do it for you, however they will charge you for doing this.
Feb 28, 2010 | Epson Stylus C42UX InkJet Printer
Epsn C42 No Yellow
The ink path is probably plugged. Try getting some ink cleaner and a squeeze bulb to purge the path IN the printer by forcing cleaning fluid into the yellow channel (cartridge removed). After it flows, it will likely take a bit to get the yellow flowing. If you have a refill kit, you could "encourage" the flow with it. Nothing you can fix by cartridge, the problem is in the printhead.
Aug 21, 2009 | Epson Stylus C42UX InkJet Printer
Both the power light and maintenance lights are blinking.
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom left corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the system tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 10, 2009 | Epson Stylus C42UX InkJet Printer
Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Dec 12, 2008 | Epson Stylus D88 InkJet Photo Printer
EPSON STYLUS C42UX PRINTER.
You say you have downloaded the SSL utility. Install it and right click the ssc icon in the system tray (bottom right corner of the screen). Select reset protection counter. This will restore your printer to a working condition.
Oct 05, 2008 | Epson Stylus C42+ InkJet Printer
Repeating
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Jul 31, 2008 | Epson Stylus C42UX InkJet Printer
C42UX problem
An unknown printer error has occurred. Turn the printer off, disconnect the interface cable and turn the printer back on. If error disappears, turn the printer off, reconnect the interface cable and turn the printer back on. If error continues then printer needs service. If printer returns to normal the issue is resolved.
Jun 09, 2008 | Epson Stylus C42UX InkJet Printer
I have had the same problem, my solution was taking a hammer to the stupid thing and buying a lexmark!
Dec 10, 2007 | Epson Stylus C42UX InkJet Printer
Internal parts out of date
I don't have the solution, mine did the same thing a couple weeks ago, just after buying a lot(15) of cartridges. I called Epson support, who wanted 10 dollars to talk to me, I talked em out of it. That kind of message means internal error. There is no fix they say, and they offered me discounts on a new printer, but the C42ux is out of production. I'm still trying to learn more to fix it myself.
Dec 19, 2006 | Epson Stylus C42UX InkJet Printer
Epson Stylus C42UX InkJet Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
