Dell latitude c640. comes up with error immediately after ram check displays... "primary hard disk drive 0 not found no boot device available - no bootable devices--strike F1 to retry boot, F2 for setup utility" Was working all ok a couple of days ago and haven't done a thing to it in the meantime. Came completely out of nowhere.
  • 47 Answers
Seems to be a problem while detecting the hard disk. Please contact customer service if the laptop is in warranty.
Let me know what happens.
Posted on Apr 30, 2008
No diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
Aug 31, 2012 | Dell Latitude C640 Intel Pentium 4-M...
Older dell latitude cpx running XP. yesterday after loading firefox and a few mozzilla add ons .. today I boot to error 0 no primary hard disk found.. bios says no hdd installed ????
Hello, Jay.
Well, as the message indicates, your hard disk drive is failing or failed. Try running your diagnostics to verify (boot and press F2 or F12 repeatedly).
If the hard drive is failing, see if someone locally can help to retrieve your documents and other files by removing the drive and setting up the drive as a slave drive on another computer.
The drive would then need to be replaced. Price the same type of drive but it may not be cost-effective to use another drive in this computer.
Hope this helps.
Oct 18, 2011 | Dell Latitude CPX Notebook
Dellc600 'primary hard drive not found nobootable device' worked
When the computer cannot "see" the hard drive, it is usally because of dead hard drive and it would need to be replaced. In this case you would see the "primari hard drive not found" and/or "no bootable device found"
You should have your computer checked by a qualified technician.
Feb 15, 2010 | Dell Latitude C610 Notebook
Primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Jul 18, 2009 | Dell Latitude C640 Notebook
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
May 22, 2009 | Dell Latitude C600 Notebook
I but a dell d600 latitud 60 hdd and 512mb,using it up to a month pluse it was tell me 0 primary hard drive not.
I assume you meant "primary hard disk drive 0 not found"? Have you pressed F12 during bootup and run the HD diagnostics? If you can't run the diags and it does not show up in the BIOS, then you have a bad hard drive.
I've seen this error many, many times on D600s.
Dec 20, 2008 | Dell Latitude D600 Notebook
D6000 DELL LAPTOP
Do you have any flash drives or external drives connected? If so unplug them and try to reboot. If not check to see if the hard drive is firmly in place sometimes they can come un hooked and that error will appear.
Oct 03, 2008 | Dell Latitude D600 Notebook
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
