Question about Mag Innovision LT776s 17" LCD Monitor
17 in Widescreen Mag Innovision
My monitor started blinking. Has been doing this for some time but now it is going completely black. I can turn the Monitor off and then back on and it will stay clear for a few moments but then goes black again. Is this a simple fix I can do and what could be the culpret?
    Novelist:
  • 119 Answers
Dear tfollis
Have you checked the HZ that you are using the monitor in windows ? If set at a very high level (for example 100hz) it may damage the monitor as it is not supporting it. (and maybe this explains the reason for the shutoff as a means to protect the circuitry)
17 inch TFT/LCD Widescreens monitors are ussualy optimal at 1280x800@60Hz.
Right click on Desktop-->Properties-->Settings-->Advanced-->Monitor--> At this point check the Monitor Refresh Frequency.
Check this first and if this does not solve it then we can proceed to more serious hardware troubleshooting.
Regards
EngineerGR
Posted on Apr 30, 2008
Problems with ON button, need multiple tries for success. Button lights up while trying, but screen stays black. I suspect the button connection. can this be checked out/fixed by user?
The start Capacitors are Blown. You are essentially building up enough current in the high voltage side to light the CCFL's. Eventually this method will fail to turn the unit on. You will have to open up the monitor and replace the defective Caps.
Jan 30, 2011 | Mag Innovision InnoVision LT765 17" Flat...
When I re-boot my PC, my monitor blinks on and off
It's normal behaviour - it blinks because during boot the pc starts with the default VGA driver, then unloads it (the monitor shuts down as the video card is disabled) then load the appropriate video driver (the monitor starts up again as the video card is activated properly).
May 06, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
I have a 17 inch mag moniter and when i turn it on the green light comes on and blinks but is really hard to get the screen to turn on. usually have to click the mouse all over the screen until it his...
Sounds like an Inverter problem. I hacked mine into the case after this happened. Running it off of the Power supply now that I figured out the pin outs for the video power.
Jan 21, 2010 | Mag Innovision LT776s 17" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
Nov 18, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Jun 02, 2007 | Mag Innovision LT776s 17" LCD Monitor
My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Feb 24, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
121 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
