I turned on my television today and found the top bottom and sides of my tv screen are bowing i see doubles red and blue and green colors tried convergence only can move blue but does not match tried perfect focus and no results what do i do I have a samsung projection television model #hcm5525w
  • shadowmanman Apr 30, 2008
    turned on tv model number ssp43w6hp bowing at top and the coulors have seperated what do i need to do to put this right have tryed every thing
  • Anonymous Aug 01, 2008
    My picture is bowed and colors don't line up. Tried flash focus.
    Sony KP-51WS500.
  • 3 Answers
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Red bow on top and bottom of 61dx01b
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
Electro Med Services...
