Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell 7920 Not Spraying Anymore
Hello...I need help trying to figure out the problem. I troubleshot as stated thru the Bissell website and no luck. I looked over the belt compartment and the belt is fine and is still turning what I assume is the pump. Could some of the lines be somehow clogged? How could I unclogged them? Please advise. Thanks!
    President:
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just refasten it down.
Posted on May 01, 2008
I have this same problem and have even replaced the pump with still no resolution. There was a lot of water in the lines so I made sure they were full of water when I attached them and the sprayer sprayed water for a few seconds then quit again. The heater isn't plugged either. A friend of mine was using it and all of a sudden it just "quit" right in the middle. When I got it back, there was dog hair everywhere "including" in the section where the water tank seals with the machine so I cleaned all of that out as well as replaced the belts, cleaned out any hair around there, etc. Any other suggestions? I'm really frustrated.
Posted on May 03, 2008
Bissell pro heat not spraying water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 06, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Water is not spraying out when button is pushed.
If it is not dispensing water then that means that the pump belt needs to be replaced. Here is the belt that you need:
Bissell Proheat Pump Belt
May 24, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Water/solution flow problem
check your belts. if your brush is not spinning when you have it on, it is a belt. goto bissell.com and there you will find on line videos to help you with this troubleshooting process, it will also tell you how to change it.
May 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Need a user manual for a bissell proheat pro-tech 7920
Go to bissell.com type in the model number 7920 then go to user guide and you can print it.
Jan 02, 2009 | Bissell 9200 Upright Vacuum
Bissell proheat 7920 replacement pump
Part number is 2107181, it will cost around $30. Most local shops shoul have this part or can order it for you. You could try bissell.com.
May 03, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Change the belt on the brush
Dear Norrfam87,here is a website with the manual for your Bissell 7920.
http://www.bissell.com/images/UserGuides/7920.pdf
On page 18 and 19,they tell how to replace the belt !
I hope this helps,EarlsOK
Dec 08, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
152 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
