I have Onkyo cd player DX7500 and when I play the cd skip constantly.
  • 4,234 Answers
Try opening up the unit and cleaning the lens using a cotton swab and alcohol. The skipping is caused by the loss of the tracking information from the disc or the motor getting stuck. While the unit is open, clean the silver rail that the optics assembly rides on using a dry cotton swab. That should resolve the problem assuming that the optics are not starting to fail. These units can be adjusted a bit as well, but that requires an alignment CD as well as some test gear. Let us know how you make out.
Dan
Posted on Apr 30, 2008
Excessive skipping
laser mechanism has gone bad. Happens after a while.
Jun 21, 2016 | Onkyo DX-C390 6-Disc CD Changer Player
Skips when playing CD or DVDs
First try a cd head cleaner. It has to work well enough to ffwd to track 4 or as instructed. If that does not work you need to open the case. Unplug power as the laser can blind you. 5 screws on the back and one each side. Lift the lid from the back to about 30 degrees and pull/ wiggle it off. Use a cotton bud wetted with alcohol (Isopropyl or surgical). You need to wipe the glass lens very very gently. wipe dry with other end of cotton bud. Recover and try.
While covers are off look for bulging capacitors or signs of black overheating.
Jan 24, 2013 | Jamo DMR 60 DVD Player/Receiver
Cd player is old and is now skipping on most tracks. Is it worth repairing?
laser will run a pretty penny...probably not...sell it 4 vintage parts
Dec 27, 2010 | Onkyo DX-C340 CD Player
My Windows Media Player skips constantly on music.
Windows media player does not skip. It plays what it can read. If you are using a CD then try cleaning it. Otherwise tell us what type of file you are trying to play.
Aug 09, 2009 | Computers & Internet
Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Jul 05, 2009 | Audio Players & Recorders
Receiver cuts out when playing a cd
Could be overheating, make sure nothing is blocking the vents at the top
Could be 4 ohm speaker when you need an 8 ohm-check speakers
Could undersized speaker wire. Go by some lamp cord and splice the ends and use it, do it anyway whether its the cause of the cutting out or not-it'll sound better
By a can of co-contact cleaner, unplug the receiver and spray the heck out of the circuits
Mar 16, 2009 | Audio Players & Recorders
CD SKIPS
  OK.  I think I can help.  There are two very simple solutions to a skipping CD player.  You have tried one already, that is, clean the laser-reading eye.  Lets assume you did that correctly and that is not the problem.         So, to continue, the machine must be opened. Equipment required: Jewellers screwdrivers, small number one screwdrivers, cottonswabs or Q-tips, Petroleum jelly, 100% isopropyl alchohol is ok but if you can use Denatured alchohol that is the best.        Using a set of fine jewelers screwdrivers or just a small #1 Regular or Philips screwdriver to remove the top cover of the CD player.  Don't force anything and place the screws in a cup so they are not lost or misplaced. I work in a plastic cafeteria tray to contain any dropped screws    The problem here usually occurs in trusty old CD players that have always worked fine and the problem (skipping) starts out small and gradually progresses to always skipping.  The problem and solution are mechanical in nature.    First locate the laser eye and check it physically for any optical obstructions (dust, dust-bunnies, lint, feathers, hair, lumber, etc.)    When you are sure the laser-eye is clean find two parallel small (usually 1/8" or about 3mm wide by about 3 to 6 inches long ) chrome metal bars that the laser eye rides back and forth on.  The eye assembly has a small contact-lens looking clear plastic lens mounted on a plastic carriage that moves from the center of the disc toward the outside as it tracks the disc.  It will have a small ribbon wire harness that can expand and retract with the travel of the laser-eye carriage.  Now look at the two-parallel shiny metal bars the carriage should slide on. The lubricant on these bars lets the eye assembly move smoothly without vibration (or skips) over the length of the two steel bars and your CD plays perfectly when they are clean and lubricated.  This skipping problem can occur if something sticky is spilled into the unit. Soda or beer dries out and if it gets on these steel bars the laser-eye assembly can vibrate and chatter as it tries to track over the CD's info causing skips.      So the solution involves carefully testing the unit with the lid off to see what is going on inside when the unit plays (or attempts to play) a CD.  If the obstruction to the path of the eye assembly is severe, the tiny drive gears can be damaged, broken, or stripped and the eye will not move smoothly without new parts (Factory Authorized Service Personnel are recommended in that case)   Use the Denatured Alchohol and swabs to completely clean and dry the steel track rods that the laser - eye slide on, take care to clean any built up old grease (manufacturer lubricant) that may build up on the holes on the sides of the Laser-eye assembly where the steel track rods go through it.  After cleaning the rods use a new swab to apply a TINY amount of petrolatum evenly to each rod.  I cannot stress enough how important it is to use as little lubricant as possible ONLY on the rods and NOWHERE ELSE!  It is very easy to get the petrolatum somewhere you don't want it.  Be Careful!  One mistake here could cost you the entire unit!  after application, physically slide the eye assembly over the bars to smooth out the petrolatum lubricant evenly. (in the event the eye-assembly doesn't manually slide, don't force anything and go to the next step). make sure you did not get any petrolatum where you did not want it, if you did clean it with cotton and good old, denatured alcohol and put a CD in and before playing it, advance the tracks from track 1 to the highest numbered track and back several times to smooth the lube more.  Play the CD and replace the lid and screws in the order you removed them.      Good Luck!
Dec 11, 2008 | Onkyo DX-C390 6-Disc CD Changer
Cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Nov 21, 2007 | Audio Players & Recorders
Cd stuck in
take the cover off and take the CD out
Oct 06, 2006 | Onkyo DX-C390 6-Disc CD Changer
60 people viewed this question
 Grubhead
Grubhead
