Everytime I turn on printer it prints out a test sheet no one knows how to fix it all I am doing is wasting my ink
Want to know how to stop my printer printing out a ink copy everytime I turn it on
    Genius:
  • 3,587 Answers
Sure..you'll need to re install the software, and then register the printer when asked.
Posted on Apr 30, 2008
Every time we turn on the printer, it prints a test sheet. how can we stop this? it's a waste of paper and ink.
Not knowing what printer or O/S you have, try this:
Open START, Control Panel, Printers.
Select the printer that needs tweaking.
It should open a pop-up screen for that printer.
Click PRINTER from top left and select "Printing Preferences" or "Properties" from the list.
Somewhere in there each manufacturer has availability to turn on or off many features of your printer, including cover page and start-up test.
This is also where you can change your default to print in grey-scale or low-mode which is also a great ink saver. MOST of what we print doesn't need to be in color or anything beyond ReadAble! When you want to print photos or special documents, it's simple to click back to color mode.
HOPE this helps ... Meezer
May 03, 2010 | HP Photosmart C3180 All-In-One InkJet...
Turn off the setting align ink catridge
go to SETTINGS , then go to DEFAULT of FACTORY DEFAULT click here, turn off PRINTER then turn ON again , see what happens , let me know , AJ
Aug 08, 2009 | HP PSC 1510 All-In-One InkJet Printer
The waste ink absorver is almost full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre to do the service job.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 23, 2009 | Canon PIXMA iP90 InkJet Printer
If the screen states E3, what does this mean and how can I fix it
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Perform these steps to reset the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Everytime i turn on the machine it prints out ''test'' page
It easy. When you turn on the printer - press and hold cancel.
Nov 12, 2008 | HP Photosmart C3180 All-In-One InkJet...
Turning printer on
Thats because the Alignment was not completed sucessfully.
Remove both the ink cartridges from the All-In-One unplug the power cord from the Printer and also from the wall outlet.
Leave it unplugged for at least about 1Min time.
Now insert the ink cartridges back to the All-In-One and reconnect the power cord to the wall outlet and Al-In-One
And after it prints the alignmamnt page make sure to align the page as per the instructions either in the computer or in the All-In-One.
For futher reference check the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336397&cc=us&lc=en&dlc=en&product=1146331
Good Luck
Oct 03, 2008 | HP Photosmart C3180 All-In-One InkJet...
Test paper
Can only think that if the printer has a menu screen there may be an option to turn off that function. If it is only happening when you use it within office software...that the option is there to switch off the function......more often than not that is the case.
Aug 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printing Test Page
you probably need to align the print cartridges. you can usually do that through the advanced printer oprions
Mar 25, 2008 | HP PSC 1350v All-In-One InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
76 people viewed this question
jasbo
jasbo
