I require a mains transformer for an A-H300 or a contact for a repair of the transformer. Part is apparently no longer available. All thats wrong with it is the thermal fuse.
  • 1,512 Answers
Hi Keith
You can often replace the thermal fuse yourself often, just got to dig for it under the layers of tape and insulator. They often have tinned leads,. If you are outside the USA, you can even just bypass it, so long as the amp still has a fuse in the primary mains cct. Its about preventing fires here, so if you are not sure then don't mess with it.
regards
robotek
Posted on Apr 30, 2008
Need a power transformer for a Mackie 1202-VLZ mixer
The transformer itself will have the codes you need to replace it either printed on it or on a label stuck to it. Mouser should have what you need.
Sep 16, 2014 | Music
Tip
Apple Compatability
iriver:
Hello! This is iriver supporter. Please enter your question, then simply click 'Go' button or press Enter key.
Maxicube:
[H10 H100 H300] apple software
iriver:
Are you asking me that "(Harddisk Player)You want Macintosh compatibility information"?
Maxicube:
Yes.
iriver:
H10 & E10 Players
H10 Players are only compatible with Windows XP. They cannot be used on Windows 98SE / Me / 2000 or Macintosh computers.
H100 Series, H300 Series and iGP players
The H100 Series, H300 Series and iGP players are compatible with Mac OS versions 9.2.2 and 10.2 or higher. When attached, the player will display as an icon on the desktop. Open the icon to add files to the player. Note, the DB functions described in the manual are not available for Mac OS at this time, as the index cannot be created with Mac OS. This means that Album, Artist, Genre, and Title searching will not be available.
For The Iriver Bot Goto http://www.iriveramerica.com/support/contact.aspx
on Feb 10, 2008 | iRiver E10 Digital Media Player
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
Hi, using my amp for a long period on new years eve and the amp suddenly died. I've changed the plug fuse and checked internal glass fuse, both ok.Cant see anything obvious I.e. burning or over heating...
There's only one way to check the transformer and that's with a voltmeter. If there is mains going in but nothing coming out of the secondary, then that fuse has gone. They are not designed to be replaced and Transformers are what the trade call 'Safety Parts'. So they have to be replaced with the same thing. I would contact Teac and find out if they still do make them or where you can get one from.
Jan 02, 2011 | Teac A-H300 Amplifier
Where I can get mains transformer KLT5P035YE for Teac A-H300? Thanks
I know this thread is a couple of years old, but this may help someone with the same problem.
There doesn't seem to be a supply of A-H300 transformers for direct replacement, but you can utilise the transformer from the MKII version of the amplifier with a little modification.
The output voltages from the MKII transformer are exactly the same, but two of the connectors have changed, so you will need to salvage these connectors from the original transformer to modify the MKII version.
The physical size is also a little different, but it will fit. I found that I had to remove the excess 'tags' that remain on the lower circuit board to give enough space for the transformer to align with two of the original mounting holes & I drilled one extra hole in the replacement tranformer baseplate so that a third screw could be used.
Hope this helps someone!
Dec 09, 2010 | Teac A-H300 Amplifier
I have a RCA T25062 TV Combo problem is, it was connected to 220volts. Do you have a schematic of chasis? Regards George
If 220 volts was connected to it, you might be looking at a few parts to repair that wont be available. It looks like the main power transformer and line input transformer are no longer available.
Sep 16, 2010 | RCA T25062 25 in. Combo
Have a Hitachi 53sdx89BA Rear Projection TV. Turn on TV and red power light illuminates. No picture, but have sound. Check PC board in back and red led is flashing and green leds are lit. It was working...
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Feb 01, 2010 | Hitachi 53SDX89B 53" Rear Projection...
Can I download owner manuals for PD-H300 mk3
i have found some you can pay to download but it would probably be best to email them at parts@teac.com and request a manual for your product.
Aug 07, 2009 | Teac PD-H300 CD Player
Replacement substitute for Fender Sunn power transformer 28-4150
I can't find a schematic that references the transformer and cannot find a replacement either. I'd contact Fender for a reccomended substitute.
Jun 22, 2009 | Music
69 people viewed this question
 Grubhead
Grubhead
